Which intake to try with holley 1050 dominator #427887
08/03/09 10:26 PM
08/03/09 10:26 PM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
If i was to run a Holley non hp 9375 dominator on my 440 dart which intake would you guys recommend. I have a pretty much box stock mopar m1 and a very ported victor 440 intake which are 4150. Or should i get a Team G or a mopar m1 4500 intake. I am running a mopar m1 tunnel ram with 2 750 carters right now. I just want to see how my car would respond to a single carb. also i am trying to see if i am having carb issues with my tunnel ram.even though this is a street car so far it has been more of a race car. please let me know what all info you need? thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Which intake to try with holley 1050 dominator [Re: mopar65] #427888
08/03/09 10:31 PM
08/03/09 10:31 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
M1 or VICTOR with 2 inch adapter
1.39 9.85 - 137 mph
Re: Which intake to try with holley 1050 dominator [Re: Ari440] #427889
08/03/09 10:44 PM
08/03/09 10:44 PM
mopar65 Offline OP
mopar65  Offline OP
hi ari440 the victor i have is the one i got off of you. so you say it is a toss up between the 2 intakes i have?? thanks Mopar65
Re: Which intake to try with holley 1050 dominator [Re: mopar65] #427890
08/03/09 10:48 PM
08/03/09 10:48 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
yes
it depends on your combo M1 makes good power at 6500 the victor wants 7000 rpm
this was I tryed out the two manifolds
and they where both with the two inch adapter and 8896 - 1050
1.39 9.85 - 137 mph
Re: Which intake to try with holley 1050 dominator [Re: mopar65] #427891
08/03/09 10:48 PM
08/03/09 10:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
It would be the cheapest route to just use the Victor, and a adapter. Im guessing you have hood clearance cause the current combo is a tunnel ram correct?. The Victor is a good piece.
And should make good power. Those old 9375's work well as single four carbs despite what some may say.
Re: Which intake to try with holley 1050 dominator [Re: Bob_Coomer] #427892
08/03/09 11:37 PM
08/03/09 11:37 PM
mopar65 Offline OP
mopar65  Offline OP
thanks guys yes i will be using a 2 inch spacer. I guess i can always bring both to the track with me and try them.so do you think the mopar m1 4500 would be a bad intake to use? I had it on my old 65 Plymouth and ran a bunch of 10.50 1/4 miles with it. but the 65 had a lot better engine than this car does right now.here is a pick of the carb. A moparts member gave me a great deal on it.also yes bob i have a hood scoop that will clear.Thanks Mopar65
Re: Which intake to try with holley 1050 dominator [Re: mopar65] #427893
08/03/09 11:57 PM
08/03/09 11:57 PM
AndyF Offline
AndyF  Offline
The Mopar M1 4500 intake is a good one as is the new Super Victor from Edelbrock.
Re: Which intake to try with holley 1050 dominator [Re: AndyF] #427894
08/04/09 12:13 AM
08/04/09 12:13 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
is this a standrd port or max wedge
how dos it compare it to the victor
1.39 9.85 - 137 mph
Re: Which intake to try with holley 1050 dominator [Re: Ari440] #427895
08/04/09 10:02 AM
08/04/09 10:02 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Ari440 - Did you do any on-track comparisons between the M1 and the Victor w/ the same carb?
Re: Which intake to try with holley 1050 dominator [Re: BradH] #427896
08/04/09 10:40 AM
08/04/09 10:40 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
the super victor is a 4500 top, you can it with standard port or max wedge size port.
Re: Which intake to try with holley 1050 dominator [Re: BradH] #427897
08/04/09 11:23 AM
08/04/09 11:23 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
not on the same day
on my moter 446 12.5 trw piston 613/276 ported stage 4 heads 4200 stall 4.56 30-10.5 slicks 3470 pound car
M1 didnt need to 7000 rpm they both ran about the same going 11.00s at the time
both manifolds port macthed, nife edge dividers ,and radius turn under the adapter into the plunuim
sorry for the spellling
1.39 9.85 - 137 mph
