ring help #427880
08/03/09 09:38 PM
08/03/09 09:38 PM
nc
E
earthmover Offline OP
E
nc
4.070 bore 340 with bme dome tops I got new total seal file fit rings the spec sheet says 18 top ring and 14 second ring what do you guys think is that to tight or will I be fine no power adder mild street motor.......
Re: ring help [Re: earthmover] #427881
08/03/09 09:47 PM
08/03/09 09:47 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
.024 top,.026 2nd and .017 min. on oil rails
Re: ring help [Re: qwkmopardan] #427882
08/03/09 09:59 PM
08/03/09 09:59 PM
nc
E
E
nc
thanks qwkmopardan read some post on your car before and man what a nice fast small block you got there.....
Re: ring help [Re: earthmover] #427883
08/04/09 03:40 PM
08/04/09 03:40 PM
UK
602heavy Offline
602heavy  Offline
UK
You'll be fine with those ring gaps , if the motor is gonna see any power adders then the rings should be gapped accordingly , those ring gaps seem pretty loose for a 4.070" bore anyhows , i would be incllined to gap the 2nd ring .002" smaller than the top ring , those iron rings will open a tad anyhows , if the motor does'nt see any high RPMs then ring flutter should'nt be an issue anyhow.
Re: ring help [Re: qwkmopardan] #427884
08/04/09 09:58 PM
08/04/09 09:58 PM
Re: ring help [Re: earthmover] #427885
08/05/09 12:04 AM
08/05/09 12:04 AM
most mild street motors don't have domed pistons.
for s true mild street combo .018-.019 top, .017 second.
