Anybody,your option on synthetic motor oil for a 440?
#427728
08/03/09 08:30 PM
08/03/09 08:30 PM
Posts: 894 Connecticut, USA
sixty7gtx
Connecticut, USA
Anybody,option on synthetic motor oil for a 440/426 ??? 15/40 ok on a old 440 or 426 hemi??
1967 Plymouth GTX, 1968 HEMI, 4 Spd. Super Bee, 2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: Anybody,your option on synthetic motor oil for a 440?
[Re: Thackdaddy]
#427731
08/03/09 09:07 PM
08/03/09 09:07 PM
sixty7gtx
Connecticut, USA
Take the time to put new gaskets on, the 1st time I put it in my 440 I did not and I had a heck of a mess. I also use 3M weatherstrip adhesive as a sealer.
ok,,, thanks...
[Re: MACDiesel]
#427737
08/04/09 03:09 AM
08/04/09 03:09 AM
Posts: 315 Russiaville, IN
mopar376d
Russiaville, IN
I have been using Penzoil 10w30 full synthetic with Wix filters for over 10 years.
It is hard to keep the motors sealed. Synthetic does tend to find a leak.
Why does divorce cost so much?
Because it is worth it!!!!!
[Re: sixty7gtx]
#427740
08/04/09 11:28 AM
08/04/09 11:28 AM
Posts: 52 Texas
shart70rt
Texas
AmsOil makes a great 20W50 Full Synthetic Racing Oil that I have used for many years in 440's. I live in the South, with many days of 100+ degree weather, so I prefer the heavier 20/50 blend. New motors need adequate break in on standard oil first, to prevent ring break in problems (AmsOil lowers friction to the point that new rings may not seat). It also cleans up gunk in dirty engines, so a good engine flush should be done first, followed by gasket changes when leaks appear on older engines.
70 Go Mango Charger RT White Vinyl Top 18 Spline 4 speed Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing 505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
[Re: sixty7gtx]
#427742
08/04/09 02:28 PM
08/04/09 02:28 PM
Posts: 74 Stevensville, ON
Frank Raso
Stevensville, ON
You can use safely use a synthetic oil for your 440 but 15W-40 is a conventional/dino grade of Heavy Duty Engine Oil (HDEO). HDEOs have higher levels of phosphorus (the antiwear component of ZDDP) than Starburst Oils and a CI-4/SL HDEOs generally have the highest levels of phosphorus. If you're using 10W-30, you can also use a synthetic 30-weight HDEO but these are generally 0W-30 and 5W-30 grades because synthetics flow extremely well at low temperatures. Being a synthetic, they also don't thin out as quickly as a straight SAE 30 or 10W-30 dino oil. Heavy Duty Engine Oils
[Re: Frank Raso]
#427743
08/04/09 07:06 PM
08/04/09 07:06 PM
Posts: 3,535 Canuckville
68Cbarge
Canuckville
Rebuilt my 440 in 2004. After intial break in with cheap oil,I have been using 20W50 Mobil 1 synthetic ever since. Nooo problems after 5 years of beating the snot out if it.
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
[Re: DennisH ]
#427744
08/04/09 07:37 PM
08/04/09 07:37 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Switched to Amsoil this change. Less cost,
Amsoil ? .. less cost ?? ... I went into a large Napa outlet last week and noticed an Amsoil display ...and was almost floored ....
$ 10.90 per quart ..
There is GOOD syn oil out there ... that anyone can buy that is about 15 beans .. for FIVE quarts.
[Re: sixty7gtx]
#427745
08/04/09 07:43 PM
08/04/09 07:43 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Fact: An SAE 20W-50 conventional motor oil flows the same as a SAE 20W-50 Synthetic motor oil. If they are both rated with the SAE spec. then they must flow the same at engine operating temp. Now if we are talking cold temperature flow, synthetics almost always flow better than conventional oils in cold temps. Fact: Synthetic motor oil does not cause leaks. Leaks can occur any time you change brands or types of motor oils whether it be conventional or synthetic. Some motor oils can leave behind deposits which can act as a supplemental seal on higher mileage engines. If your main crank seal is bad and you have gunk protecting it from oil deposits, then you probably have no-or-minimal leaks. Now you switch to another brand; it could be conventional or synthetic, both of which have differing levels of detergents and other additives than the oil that you were just using. These differing additives eat away at the gunk that was acting as a supplemental seal and now you have a leak. The issue was not the oil change, but rather a worn out crank seal. Fact: There are many synthetic motor oils that have the same or higher levels of Zinc and Phosphorous as Heavy Duty Engine Oil (HDEO). Example:
[Re: dOc !]
#427746
08/04/09 07:49 PM
08/04/09 07:49 PM
CompSyn
Pacific NW USA
DennisH is not talking about On-The-Shelf-Retail cost as you saw at Napa. He's talking wholesale cost.
[Re: CompSyn]
#427747
08/04/09 08:55 PM
08/04/09 08:55 PM
sixty7gtx
Connecticut, USA
Example:
[/quote
What is a good zine level, ? ppm?
