one wire alternator #427633
08/03/09 08:02 PM
08/03/09 08:02 PM
Anonymous OP
Anonymous OP
can some one tell me how and what i need to do to hook up a one wire alternator into my 66 belvedereII with a big block its a 140 amp alternator and ive got electronic ignition
thanks cliff
Re: one wire alternator #427634
08/03/09 08:31 PM
08/03/09 08:31 PM
AndyF Online content
AndyF  Online Content
Hook the one wire up to the hot stud on the starter relay so it can charge the batt in the shortest possible path. The one wire alternators don't really work all that great on a street driven car so you'll want to stay on top of it with a voltmeter.
Re: one wire alternator [Re: AndyF] #427635
08/03/09 10:03 PM
08/03/09 10:03 PM
NJ
440challenger Offline
NJ
I ran a 14 gauge wire to the trunk mounted battery with an inline maxi fuse. Why is it better to hook it to the start relay?
Re: one wire alternator [Re: 440challenger] #427636
08/03/09 10:29 PM
08/03/09 10:29 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I have been running mine on the street for years this way
Re: one wire alternator [Re: 440challenger] #427637
08/03/09 10:30 PM
08/03/09 10:30 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
There is no problem with running it back to the trunk but you better have something bigger than a 14, thats smaller than speaker wire, you should be using a 6 or 8 and instead of a fuse you should use a fusable link
Re: one wire alternator [Re: GTXKen] #427638
08/03/09 10:47 PM
08/03/09 10:47 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I didn't catch that
Re: one wire alternator [Re: 440challenger] #427639
08/03/09 10:49 PM
08/03/09 10:49 PM
Anonymous OP
Anonymous OP
Why would you run a separate wire to the trunk when you already have a nice big fat battery cable going back there, and of all things, one that small?
The MAIN LOAD after initial start and after initial battery recharge is the LOADS IN THE CAR like the AC, rad fan, whatever, not the battery. It's important to have the proper regulated system voltage UP FRONT not dropped through a huge long cable back and forth from the trunk.
Re: one wire alternator [Re: 440challenger] #427640
08/03/09 11:53 PM
08/03/09 11:53 PM
Sounds like a good way to start a fire.
Re: one wire alternator [Re: AndyF] #427641
08/04/09 12:09 AM
08/04/09 12:09 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Does the single-wire alternator still need a voltage regulator ???
Re: one wire alternator [Re: Stanton] #427642
08/04/09 12:28 AM
08/04/09 12:28 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
no,it's built in
Re: one wire alternator [Re: GTXKen] #427643
08/04/09 09:21 AM
08/04/09 09:21 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Speaker wire is right! 140 amp minimum doubled 10
but should be 6 or 4.
and on a race car you must have it isolated from the car by the cut off switch so it allows car to shut off when power switch is turned off
Re: one wire alternator [Re: Dodgem] #427644
08/04/09 07:17 PM
08/04/09 07:17 PM
Anonymous OP
Anonymous OP
what bout my balis resistor and my external regulator being as this one is internally regulated how do i by pass them or dont i need to
Re: one wire alternator [Re: 440challenger] #427645
08/04/09 07:34 PM
08/04/09 07:34 PM
NJ
NJ
Ok well i checked the wire and its 10 gauge not 14 but i will still get a thicker wire and go to the starter relay lug instead. I have the battery and msd hooked to it now, how much stuff can you have on that one lug before its considered overloaded?
Re: one wire alternator [Re: 440challenger] #427646
08/04/09 11:17 PM
08/04/09 11:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The lug is simply that - a lug. The weak links would be the connectors or wires themselves.
Re: one wire alternator [Re: 440challenger] #427647
08/05/09 09:18 AM
08/05/09 09:18 AM
GTXKen Offline
super gas
GTXKen  Offline
super gas
Per MSD the MSD box should not be hooked up directly to the Alt output
Re: one wire alternator [Re: AndyF] #427648
08/05/09 02:30 PM
08/05/09 02:30 PM
O
OLD318 Offline
OLD318  Offline
O
I'm lost,
Why would'nt a one wire, internally regulated
alternator work good on a street car?
I would bypass the full flow amp guage on the dash per www.madelectrical.com writeup,
and I would definitely run at least an 8 guage wire from the alt to the stud on the starter relay.
But other than those two wiring considerations,
why wouldnt they work?
Am I missing something?
Re: one wire alternator [Re: OLD318] #427649
08/05/09 02:47 PM
08/05/09 02:47 PM
IL
furious70 Offline
furious70  Offline
IL
the argument goes that the 1 wire doesn't 'sense' voltage in the correct place, hence you'll actually be running low voltage to most accessories and your alt won't 'see' it.
I have mine wired via 2g to the starter post and draw power for the amp, efi ecu, and fuel pump relay from the same post. When wired this way I don't see any problem. If you wire your 1 wire the old 'tractor style' with the charge wire straight to the battery, then you can potentially have enough voltage drop through the harness that your stuff is running low voltage.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: one wire alternator [Re: furious70] #427650
08/05/09 05:26 PM
08/05/09 05:26 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Mine is wired to the battery in the bed of my Dakota. This set up seems to work great for charging. I have electric fan, fuel pump, MSD , and all of the other electrical items a street legal vehicle needs. This way I can shut off the master disconnect and kill the engine. This is the way I was shown so I am legal to race. I still drive on the street and use the shut off when parked. No chance of an electrical fire with the battery disconnected.
Re: one wire alternator [Re: furious70] #427651
08/05/09 05:38 PM
08/05/09 05:38 PM
O
OLD318 Offline
OLD318  Offline
O
I thought that was only a problem if the 1 wire
alternator was connected directly to the battery terminal. If you do the full flow amp guage bypass (per MAD Electrical writeup) and wire the
alternator to the stud on the starter relay this should not be a problem... at least that's how I
understood it...
See www.madelectrical.com for the discussion of this....
Re: one wire alternator [Re: OLD318] #427652
08/05/09 05:46 PM
08/05/09 05:46 PM
IL
furious70 Offline
furious70  Offline
IL
yes old318, that's what I'm saying. Though MAD tries to sell their 3 wire kits rather than tell you how to correctly wire a 1 wire I thought.
I would think that Dak would have a voltage drop to the fans, would be interesting to test with a multimeter.
70 Sport Fury
68 Charger
69 Coronet
72 RR
