Rim Screws or Not? #427557
08/03/09 06:13 PM
08/03/09 06:13 PM
Seaford Delaware
JSR1485 Offline OP
JSR1485  Offline OP
Seaford Delaware
I had my new tires mounted and found out when we went to balance them that they where bent. Since I have to buy new rims now not sure if I need to screw the slicks to the rims. The tire size is 30x11.50 Goodyears and the engine makes about 600hp. I have never ran screws before, but they where on old rims and not sure if I need to drill my new rims or not? How many of you guys run screws?
Switched to the dark side...
Re: Rim Screws or Not? [Re: JSR1485] #427558
08/03/09 06:17 PM
08/03/09 06:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think this comes up about once a month.... do a
search.... makes a difference on the tire pressure
Re: Rim Screws or Not? [Re: MR_P_BODY] #427559
08/03/09 06:36 PM
08/03/09 06:36 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
DragRadials here , NO screws, been 1.24 60 foots
Yes they have moved a lot, one is almost one full rotation now, never vibrated etc, Prob moved 1 inch or less each pass
If you research it you will find 99.9% of Stock and Super Stock cars DO NOT run wheel screws or tubes
....BAD A$$ STREET CAR.....
Re: Rim Screws or Not? [Re: n20mstr] #427560
08/03/09 07:01 PM
08/03/09 07:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
do you think a tire moving 1" on a pass will effect RT? and do you think it will move the exact amount every pass?
Re: Rim Screws or Not? [Re: MR_P_BODY] #427561
08/03/09 07:01 PM
08/03/09 07:01 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Hello Mr P Body. Could you elaborate please. I just added wheel screws to my car. I spun a tube & it punctured. Did not reinstall tube. Suprisingly PSI is constant. Is that what you mean?
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: Rim Screws or Not? [Re: rockerbob] #427562
08/03/09 07:08 PM
08/03/09 07:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On a low pressure tire like my set up 7 psi I can
spin the tire on the rim real easy... unlike a car
that uses a higher pressure... higher pressure you
have more force holding the tire to the rim.... I
screw the rims and use tubes
Re: Rim Screws or Not? [Re: MR_P_BODY] #427563
08/03/09 07:13 PM
08/03/09 07:13 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Thanks, I understand what you meant now.
Re: Rim Screws or Not? [Re: rockerbob] #427564
08/03/09 07:17 PM
08/03/09 07:17 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Did you lose the tube after installing the screws? if you did you didn't install the tubes correctly or you didn't use racing tubes.
Re: Rim Screws or Not? [Re: rockerbob] #427565
08/03/09 07:24 PM
08/03/09 07:24 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
For the safety of using screws and about $14.00,why would you risk it.
Re: Rim Screws or Not? [Re: SCDaytona] #427566
08/03/09 07:26 PM
08/03/09 07:26 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Yes
Re: Rim Screws or Not? [Re: 69CHARGERMD] #427567
08/03/09 08:23 PM
08/03/09 08:23 PM
CT
turbocolt2.4L Offline
CT
yes on the screws if the tire spins on rim enough you could blow a bead then you will be SCREWED.just my 2 cents
Re: Rim Screws or Not? [Re: rowin4] #427568
08/03/09 09:49 PM
08/03/09 09:49 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Nope, tubes had been in for two seasons. A month or so ago in the first round the car didn't feel right going down the track. When I got back to the pit I saw the tire was down. I removed the tube and installed a metal valve stem. Reinflated the tire. My fellow racers/friends looked at the tube & saw a small hole. No whole in tire however so it was determined that the tube had pinched. Just one of those things I guess. I since have installed the screws. Still have a racing tube in the other side. 1 side has a tube the other now doesn't. Air psi has been rock steady to my suprise. 18 psi when I unload after sitting in trailer all week. 18 1/2 when the sun hits it. 17 1/2 after dark. Both sides. I have tried several psi's & this range seems to work.
Re: Rim Screws or Not? [Re: rockerbob] #427569
08/03/09 09:58 PM
08/03/09 09:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When using tubes..... use lots of talc/baby powder
Re: Rim Screws or Not? [Re: MR_P_BODY] #427570
08/03/09 10:23 PM
08/03/09 10:23 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Yep, so I have been told. I'm fairly new to this board. Wish I had been on here years ago. Thanks Mr. P you know your stuff
Re: Rim Screws or Not? [Re: rockerbob] #427571
08/03/09 11:11 PM
08/03/09 11:11 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Srew it and tube it for bias plys. Radials I ll defer.
The little old lady from Pasadena is back!
Re: Rim Screws or Not? [Re: Barnstorm] #427572
08/04/09 12:07 AM
08/04/09 12:07 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Like Barnstorm says. Over 600HP and at 7.5PSI with a spool, I don't want ANY tire slippage on the rim. Personally, I'd screw the tires to the rims on anything that hooks well, and the last time I checked, hooking is a major part of the run.
Re: Rim Screws or Not? [Re: topside] #427573
08/04/09 07:54 AM
08/04/09 07:54 AM
an8sec70cuda Offline
Bias ply tires I always had screws and tubes in them. I ran rubes b/c I still drove it on the street and didn't like having to air up the tires every other day.
I run radials now w/ screws. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Rim Screws or Not? [Re: JSR1485] #427574
08/04/09 09:05 AM
08/04/09 09:05 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
We never screw the tires on the Stockers. 9" @ 10.5psi stick car that hammers the tires initially. Even on Hemis cars, no screws but with a radial @ 16psi.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Rim Screws or Not? [Re: sixpackbee] #427575
08/04/09 09:12 AM
08/04/09 09:12 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
No screws, tires have never moved
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Rim Screws or Not? [Re: sixpackbee] #427576
08/04/09 09:16 AM
08/04/09 09:16 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
'68 Cuda runs 11s 26x10 MT on 15x8 wheels 17psi no screws
'71 Cuda runs mid 9s 14x32 GY on 15x12 wheels 7.5psi 4 screws on the inside, none on the outside.
Rear Engine Dragster runs high 7s 16x33 on 15x15 wheels no screws 5.5psi
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
