Page 1 of 3 1 2 3
QUEST FOR TENS #427342
08/03/09 01:49 PM
08/03/09 01:49 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I made a post on sunday and I guess I should have been more clear my bad.
my junk right now is running in the low 11s and I think Iam at the max et with my eddie heads.I have a set of Indy cnc 230 heads and the matching hardware to go with it at my disposal.Should I put the heads on and run it,they should get me into the 10s or should I just save them for a new short block.The motor in the car now is a good motor with about 50 runs and internal balance.It has probe pistons a mopar cast crank and eagle I beam rods.Do you guys think the rods and the crank will hold or am I playing with fire?No power adders put on later just all motor.I am only looking for 3-5 tenths or am I dreaming that with just a head swap.
Thanks in advance and pinch me If I am dreaming.
Re: QUEST FOR TENS [Re: Scamp408] #427343
08/03/09 01:57 PM
08/03/09 01:57 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I think your engine should handle 11.0's no problem. I think with the other heads, your cast crank, may or may not handle it too well. If it were me, I would save those heads for another build, or put them on. I just wouldn't run it that way for too long.
Re: QUEST FOR TENS [Re: viperblue72] #427344
08/03/09 02:07 PM
08/03/09 02:07 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
What cam are you running?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: QUEST FOR TENS [Re: Scamp408] #427345
08/03/09 02:11 PM
08/03/09 02:11 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
To keep us from searching through your posts, can you give
us a run-down on engine, converter, gear and vehicle?
10s are pretty easy with 4"+ crank SB.
Re: QUEST FOR TENS [Re: S/ST 3040] #427346
08/03/09 02:57 PM
08/03/09 02:57 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
eddie heads victor340 intake,557lift solid cam,410 gears lupo trans and convert,825carb,tti headers,28in tire,car weight 3150 with me.best 1.51 60ft 7.026 1/8 9.25 1000ft 11.17 1/4 117.55mph.
Re: QUEST FOR TENS [Re: Scamp408] #427347
08/03/09 03:05 PM
08/03/09 03:05 PM
S/ST 3040 Offline
S/ST 3040  Offline
Without know any more specs for the cam and converter, it's a
little on the weak side for a 408. (about 395 HP)
It might be in there already with some sharp tuning but, the
heads, more than likely, have the HP corked up.
Good tire/gear selection.
What are the rest of your cam specs and CR?
Re: QUEST FOR TENS [Re: S/ST 3040] #427348
08/03/09 05:50 PM
08/03/09 05:50 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
INTAKE: Duration: 304º Lift: .545
EXHAUST: Duration: 310º Lift: .558
lupo 9.5 4200 stall convert
The motor was orig built for the 12s so I know the cam is weak.I talked to lupo about going to an 8in he said I may p/u a 10th but he thought is wasnt worth it.
Re: QUEST FOR TENS [Re: Scamp408] #427349
08/03/09 06:03 PM
08/03/09 06:03 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Better cam will get you there
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: QUEST FOR TENS [Re: Scamp408] #427350
08/03/09 08:21 PM
08/03/09 08:21 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I have heard the Eagle i beam rods have a bad reputation. I think i would save those heads for another motor.
Re: QUEST FOR TENS [Re: forphorty] #427351
08/03/09 10:43 PM
08/03/09 10:43 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
is that a 825 demon or holly take 2 jet sizes out and see if mph picks up and if it does you are tad rich and if it slows try 2 other way , when that is sorted try increaseing timmimg by 2 degrees
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: QUEST FOR TENS [Re: Ian] #427352
08/03/09 10:55 PM
08/03/09 10:55 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I would change the cam loosen the conv. to 5,400 and put 4.30 or 4.56 in it.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: QUEST FOR TENS [Re: bdaz smblk] #427353
08/03/09 11:33 PM
08/03/09 11:33 PM
S/ST 3040 Offline
S/ST 3040  Offline
Since it's 11.4:1 CR. I'd use a cam like 262º/266º @ .050,
108º LSA, installed +4º .590"+ lift.
Open up the heads/valve job
A little more stall wouldn't hurt but, not necessary.
I'd keep the 28"tire/4.10 gear......especially w/TTI (1 5/8"?)
With bigger headers, open exhaust probably 10.70-10.80
Re: QUEST FOR TENS [Re: S/ST 3040] #427354
08/04/09 05:19 AM
08/04/09 05:19 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Its a 11.4 motor.The carb is already jetted up 2 steps.With a lm o2 a/f in the 12 range could be a little rich.I tried the timing all over and likes it around 32 total.I realy dont want to put money in the eddie heads thats why I have the Indy ones.
I was going to just put the head on but I have been reading all the stories about eagle rods snapping.
Re: QUEST FOR TENS [Re: Scamp408] #427355
08/04/09 06:03 AM
08/04/09 06:03 AM
Q
Quicktree Offline
Quicktree  Offline
Q
the indy heads will make way more power than the cast crank and eagle I beams can handle.
Re: QUEST FOR TENS [Re: Quicktree] #427356
08/04/09 06:52 AM
08/04/09 06:52 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I also don't think putting the Indy heads on with that cam, headers, carb, stall and compression would do just a whole lot for you in terms of e.t.
14x Track Champ
Re: QUEST FOR TENS [Re: Jacob Pitt] #427357
08/04/09 08:23 AM
08/04/09 08:23 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I have the tti 1-7/8 headers for the Indys and a bigger carb that need to be redone.At that lift the Indy heads flow alot more than the eddies thats why I thought I would make more power with just a head swap.I may be at the limits of the cast crank and rods.
Re: QUEST FOR TENS [Re: Scamp408] #427358
08/04/09 08:38 AM
08/04/09 08:38 AM
S/ST 3040 Offline
S/ST 3040  Offline
Jacob might be messing with you, since he runs the 360-2 heads.
Make no mistake, the INDYs are a HUGE improvement over Edelbrocks.
I'll edit my cam specs for 11.4:1
Re: QUEST FOR TENS [Re: Scamp408] #427359
08/04/09 08:49 AM
08/04/09 08:49 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IMHO you have a couple issues, smallish carb and small headers and the 60' seems a little slow. At you're weight it should be in the 6s in the 1/8 now. My old hydraulic cammed, pump gas 340 went mid 7.20s with a best 1.533 60', it normally went 1.55-1.57. 69 Dart, 3300#, 9.5" 4400 converter with 4.30 gears. If you're chassis was sorted out you'd be there now .
Re: QUEST FOR TENS [Re: justinp61] #427360
08/04/09 08:55 AM
08/04/09 08:55 AM
S/ST 3040 Offline
S/ST 3040  Offline
He'd have to be a real chassis whiz to hit 10s @ 117.
Re: QUEST FOR TENS [Re: S/ST 3040] #427361
08/04/09 10:23 AM
08/04/09 10:23 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
The cam was picked for a 12 sec ride but I have been tweeking this and now its in the low 11s.
I have the 002/003 springs with comp 3 ways and the .810 torsion bars with Qa1 drag shocks.I can get a bigger carb if needed.
Page 1 of 3 1 2 3
