TQ gas smell #426097
08/02/09 10:18 AM
08/02/09 10:18 AM
Southern CA
Colin Frolick Offline OP
Southern CA
lately when i get into the secondaries on my thermoquad i smell gas in the car. it runs fine. any thoughts?? thanks
Re: TQ gas smell [Re: Colin Frolick] #426098
08/02/09 12:45 PM
08/02/09 12:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Trunk seal?
Re: TQ gas smell [Re: Dodgem] #426099
08/02/09 03:09 PM
08/02/09 03:09 PM
Southern CA
Southern CA
nah that's always been bad
it seems to be coming from under the hood, like it's coming in thru the fresh air vents. i'll try to check for leaks. could something inside the carb make it just dump more fuel when the 2ndaries open?? more reason to get an a/f meter already.
Re: TQ gas smell [Re: Colin Frolick] #426100
08/02/09 08:55 PM
08/02/09 08:55 PM
Could be one of two things, or combo. The fuel pump could be over powering the floats. Set the floats 1/16 inch higher than spec. Or, the secondaries are too rich. jet down on the dump tubes.
Re: TQ gas smell [Re: Colin Frolick] #426101
08/02/09 08:59 PM
08/02/09 08:59 PM
After you get into the secondaries(& smell gas) pull over & see if you see any gas leakage on the outside of the carb
Re: TQ gas smell [Re: RapidRobert] #426102
08/02/09 10:50 PM
08/02/09 10:50 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Even if you're jet real rich you shouldn't smell it through the vents at speed. I can see smelling it through the exhaust but you must have a leak if you're smelling it thru the vents. I'd check the carb as well as the fuel lines/connections after you nail it and get the smell.
