alt guage #425763
08/01/09 08:06 PM
08/01/09 08:06 PM
Mid Michigan
2
2BEEZ Offline OP
2BEEZ  Offline OP
Mid Michigan
my alt guage needle moves erradically at all rpms 69 road runner
Re: alt guage [Re: 2BEEZ] #425764
08/01/09 08:33 PM
08/01/09 08:33 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I'm guessing your mechanical voltage regulator may need replacement.
However, before you do that clean all your connections, especially the battery and connections to the alternator. Then check the gauge again.
Re: alt guage [Re: dynorad] #425765
08/01/09 08:51 PM
08/01/09 08:51 PM
Mid Michigan
2
2BEEZ Offline OP
2BEEZ  Offline OP
Mid Michigan
thanks i will check it out and post results
Re: alt guage [Re: dynorad] #425766
08/01/09 10:28 PM
08/01/09 10:28 PM
Might get an electronic parts house replacement & someone here had a black OE appearing unit for $25 to your door.
Re: alt guage [Re: RapidRobert] #425767
08/01/09 10:51 PM
08/01/09 10:51 PM
Castlegar, BC, Canada
That AMC Guy Offline
Double check all grounds at the voltage regulator and engine block.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: alt guage [Re: That AMC Guy] #425768
08/02/09 01:23 AM
08/02/09 01:23 AM
This can be cause by a number of things
ammeter got hot, loosened up, and has poor connection.
Poor connections ANYWHERE in the harness, including connectors, in-harness splice(s) the bulkhead connector, and the alternator itself, including brushes and a partly shorted stator.
In the dark, engine running, lift the hood. Turn on a heavy load, like the heater motor. Rev the engine up/ down and look for "lightning" in the alternator. If you can see sparks coming from the stator windings, they are shorting from vibration and have come loose, worn off the insulation.
Can also --depending on how the meter is acting-- a worn/ slipping fan belt
Re: alt guage [Re: 2BEEZ] #425769
08/02/09 08:05 AM
08/02/09 08:05 AM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
Mine 69 dart did the same thing, also the lights would flicker, I just changed the voltage regulator to a modern replacement, problem solved, ammeter is always steady now.
Re: alt guage [Re: dd340] #425770
08/11/09 07:13 PM
08/11/09 07:13 PM
Mid Michigan
2
2BEEZ Offline OP
2BEEZ  Offline OP
Mid Michigan
CHECKED ALL CONNECTIONS NO LUCK, NEW REGULATOR DID THE FIX. THANKS FOR THE INFO.
