96 NEON STARTER ISSUE #425468
08/01/09 11:42 AM
08/01/09 11:42 AM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Daughter's 96 SOHC Neon, I think, needs a starter. Before I spend $100+ on it, and not need it, what else should I check prior to replacing it? It makes a strange sound, like maybe something internal. Went pretty quick actually.
It's probably the issue, it's got 170K on it, and never been replaced.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 96 NEON STARTER ISSUE [Re: Magnumguy] #425469
08/01/09 11:50 AM
08/01/09 11:50 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Need more info than It makes a noise.
Re: 96 NEON STARTER ISSUE [Re: stumpy] #425470
08/01/09 11:58 AM
08/01/09 11:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Some had a problem with the exciter wire.They corroded.But at that milage Id say starter.Rocky
Chrysler Firepower
Re: 96 NEON STARTER ISSUE [Re: stumpy] #425471
08/01/09 12:19 PM
08/01/09 12:19 PM
S.E.Ohio
S.E.Ohio
Doesn't "roll over" but makes a buzzing/sizzling sound?
Cables all appear to be clean and well connected. Which ones' the "exciter"? Also, battery's good.
Re: 96 NEON STARTER ISSUE [Re: Magnumguy] #425472
08/01/09 12:44 PM
08/01/09 12:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The small wire.What is the starter doing or not doing?Rocky
Chrysler Firepower
Re: 96 NEON STARTER ISSUE [Re: therocks] #425473
08/01/09 04:48 PM
08/01/09 04:48 PM
S.E.Ohio
S.E.Ohio
OK, where's that last bolt for the starter? Got the one the ground cable hooks to......
Re: 96 NEON STARTER ISSUE [Re: Magnumguy] #425474
08/01/09 07:28 PM
08/01/09 07:28 PM
S.E.Ohio
S.E.Ohio
Well, it was the starter. Not the easiest starter to change.
