Re: anyone restore factory speakers.
[Re: cataclysm80]
#425275
08/01/09 11:22 AM
08/01/09 11:22 AM
Most people seem to buy their factory replacement speakers from turnswitch.com. That is if you're using a factory radio. Aftermarket radio's would use different speaker ohms.
Most so called speaker restoration places plate/re-cone, but don't have the equipment to properly re-magnetize the magnet. Do you plan on listening to your radio? Big_Money_Lewis has more info on this stuff.
Tav
i just went through the same thing with my a12 superbee. i got the one from turnswitch.com, instead of reconing the old one.its not worth the aggravation and cost,unless you have a oe gold car, go with the factory replacement from turnswitch, once its under the dash you'll never see it. also Gregs customer service is excellant.
[Re: TB3CUDA]
#425276
08/01/09 12:04 PM
08/01/09 12:04 PM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
turnswitch fixed my radio and i bought their new replacement speakers for my Challenger. the speakers are real nice. they are not an EXACT replacement. i have a 3 speaker dash so i got the 4x10 and the 2- 3 1/2" speakers. i had to trim the dash for the 4x10 and one of the 3 1/2", but after the new dash pad went on, you can't see it. they did my radio for $192 with the shipping and i bought it for $220 with shipping. i have less than $500 into an e-body radio, which i think is great. a lot of members recommended them from reading the posts so i called and sent out my radio. i am very happy with their work. when i got it back and installed it in the car, i connected a jump box to test it out and it sounded great. probably much better that it was out of the factory. oh, and as for the factory connectors, i cliped the old leads and soldered them on to the new speakers
[Re: TB3CUDA]
#425279
08/01/09 12:43 PM
08/01/09 12:43 PM
Posts: 1,782 Miami, FL
wylde8
Miami, FL
I had mine done by a local guy who fixed car radios. He reconed it and rewired it for $30.
1971 Dodge Charger
At Moparts, the concensus is there is no consensus.
[Re: wylde8]
#425280
08/01/09 12:49 PM
08/01/09 12:49 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Wow, lot of variation in price.
[Re: joelson6]
#425283
08/01/09 05:51 PM
08/01/09 05:51 PM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
For the money, I believe new speakers from turnswitch.com are the way to go. I recomend them to my customers, and never heard any complaints. Greg Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios We can restore YOUR radio usually in less than 14 days Visit our NEW website.. http://www.wardsclassiccarradiorepair.comgregward@mchsi.comphone 256-852-0955
[Re: BigMoneyLewis]
#425285
08/05/09 12:23 PM
08/05/09 12:23 PM
Posts: 1,912 Anchorage, Alaska
Iceman01
Challenged
Challenged
Anchorage, Alaska
Greg
Hang on folks.
Literally yesterday, I sent Turnswitch's new model E-body 4"x10" oval replacement speaker back for refund. IT DOES NOT FIT the factory hole in the dash. Very close, but won't go down flush into the hole due to a differently stamped/shaped metal basket. I could screw it in, but the grille would then not sit flush with the rest of the dash. NOTE: My dash is completely original and unmodified, and I also had the original speaker with which to gauge the differences.
The Turnswitch replacement speaker has a squared off, uniform-depth, metal basket frame. But if you look closely at a factory Mopar speaker you will see it has a rounded metal basket frame and each side (when viewed from the long axis) is a different depth. Then look into the speaker hole and you'll see another layer/shelf of the dash frame a couple of inches below and kinda offset to the center of the speaker hole. That underlying piece is why the speaker's metal basket frame can't be square or uniformly shaped/depth if it is to fit properly.
Called Turnswitch and the guy was good about it. He said that model is a universal fit thing for a lot of GM models (primarily Corvettes) and no one had as of yet reported the E-body problem to him. Told me to send it back for a refund.
Until total honesty is on the table, we're not even talking about reality...
[Re: TB3CUDA]
#425286
08/05/09 06:36 PM
08/05/09 06:36 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Try www.simplyspeakers.com They re-cone speakers & may be able to help. I istalled the Turnswitch repops in my Chally w/ 3 speaker dash option & fits & sounds great. Turnswitch even drew a wiring installation diagram for me. Good luck w/ your situation.
[Re: Triggerfish]
#425287
08/05/09 10:35 PM
08/05/09 10:35 PM
Posts: 156 Detroit, Mi
michiganhotrod1
Detroit, Mi
Try this guy: Jackson Speaker Service, 3921 Pinecrest Ct, Jackson, MI 49203, 517-789-6400; email: rmcgee08@comcast.netHe has done both car and old radio speakers for me, very reasonable. Been around for many years.
