Page 1 of 3 1 2 3
Shop Floor Coverings #425045
07/31/09 09:00 PM
07/31/09 09:00 PM
MR_P_BODY Offline OP
I know there was a post some time back on this but
cant find it.... So, what do you guys think is the
best floor covering for a shop... needs to be durable
and hopefully wont break the bank... let me hear
what ya think.... I'm thinking some type of epoxy
but open to all ideas
thanks
Re: Shop Floor Coverings [Re: MR_P_BODY] #425046
07/31/09 09:08 PM
07/31/09 09:08 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Not sure on price BUT If I was building a new shop I would look into polished concrete.
Re: Shop Floor Coverings [Re: MR_P_BODY] #425047
07/31/09 09:08 PM
07/31/09 09:08 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Don't know how expensive but a few years ago the company I work for had a company come in and coat the floors in the aisle area's with an epoxy that was made by Sherwin William's and it is tough as steel and still look's good.
Re: Shop Floor Coverings [Re: SSAAHemiFan] #425048
07/31/09 09:10 PM
07/31/09 09:10 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that would look good also.
Re: Shop Floor Coverings [Re: MR_P_BODY] #425049
07/31/09 09:11 PM
07/31/09 09:11 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My neighbor used the Rust-o-leum stuff over 4 years ago in his garage and with daily use it's holding up great.
Nautilus Racing-
Re: Shop Floor Coverings [Re: SSAAHemiFan] #425050
07/31/09 09:19 PM
07/31/09 09:19 PM
Well when I started this project/shop I went with in
concrete heating and a high trowel finish floor 6"
thick... but I want something thats not going to
stain... I'd like to go with a bright gray color
or some other bright color, I like bright areas
Also I do alot of welding and fabricating so it needs
to stand up to that type of stuff
Re: Shop Floor Coverings [Re: MR_P_BODY] #425051
07/31/09 09:49 PM
07/31/09 09:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
most any color will chip and scratch, should have tinted the concrete when pouring if you wanted color. I stained mine and it stiil scrathes. the polished concrete is the way to go.
Re: Shop Floor Coverings [Re: Quicktree] #425052
07/31/09 10:02 PM
07/31/09 10:02 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
On my last shop I used the Sherwin-WIlliams stuff
on the work area and the behr on the traffic areas
The Sherwin-wiliams stuff after 5 years of abuse looked great still ..bit expensive though, not awful
On my new shop I used the kits from Home-Depot or Lowes from Rustoleuom and after 4 years it still looks good and is holding up well
If your eyes are weak, don't use the chips cause its hard to find small pieces if you drop them
It can be a bit slippery if water gets down
My shop is 1000 sq ft and I used 3 and 3/4 kits to
cover it
Even if the kits say they will cover 500 sq feet I think it was ..Kits cost about 65 bucks IIRC
Get a helper to shake the chips out if you use them
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Shop Floor Coverings [Re: Quicktree] #425053
07/31/09 10:08 PM
07/31/09 10:08 PM
I tried stianed/colored concrete before... wasnst
bright enough for me
Re: Shop Floor Coverings [Re: bigdad] #425054
07/31/09 10:13 PM
07/31/09 10:13 PM
cover it
Does either company(Rustoleum or Sherwin ) offer
a clear coat to cover the base coat, I'm putting
a logo on the floor and need to clear over it
Re: Shop Floor Coverings [Re: MR_P_BODY] #425055
07/31/09 10:20 PM
07/31/09 10:20 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
cover it
Yes .. You can get clear in the rustoleum stuff
But, beware ..IT DOES GET VERY SLICK !!
One fast move BOOM !!
The truth is, it stays pretty nice , not much or limited chipping
I hit the dirty spots with some brake cleaner(That stuff is weak anymore) and them mop it out
I'd use the Sherwin-williams stuff again but, its about 2 1/2 times the cost IIRC it was $90 a mixed gallon 8 years ago so, I'm sure its gone up
I can't post pics from this puter, on the road but can if you need to see later
The home-depot stuff works well, don't use the Behr paint .Horrible
Re: Shop Floor Coverings [Re: bigdad] #425056
07/31/09 10:22 PM
07/31/09 10:22 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Oh yeah, one last thing
Contact a local sign shop and put a logo on the floor and bury it in the coating , it will look awesome !!
MR. P Performance !!!
Re: Shop Floor Coverings [Re: bigdad] #425057
07/31/09 10:29 PM
07/31/09 10:29 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Go here and read .might be more than you want to know LOL
http://www.garagejournal.com/forum/forumdisplay.php?f=20
Re: Shop Floor Coverings [Re: bigdad] #425058
07/31/09 10:29 PM
07/31/09 10:29 PM
RIFF-RAFF
.RACING
Re: Shop Floor Coverings [Re: MR_P_BODY] #425059
08/01/09 12:13 AM
08/01/09 12:13 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I would think that a polished floor would be the last surface that you would want in a garage, water, oil, grease, unless you just polish your car in it, you will be on your back before you know it. I would put down a light grey epoxy coating with a slight non slip texture that would be easy to wipe and sweep up.
Re: Shop Floor Coverings [Re: rowin4] #425060
08/01/09 07:52 AM
08/01/09 07:52 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
I used a water borne epoxy from ICI that I added some of their fine granuals to to prevent a super slick floor when it gets wet. My floor has been done for about 8 years +/- and is holding up great. No chipping, peeling, no nothing. Key to a good job is always in the prep. Be sure to follow the manufacturers instructions and you won't have a problem. Ask MR2 Performance, he has seen my floor.
Re: Shop Floor Coverings [Re: Mopar Grandpa] #425061
08/01/09 07:58 AM
08/01/09 07:58 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it all depends on what you use it for. if you just park a car in it or you really do a lot of shop work. believe me it will chip or scratch if you drag something over it.sometimes it can't be helped.
Re: Shop Floor Coverings [Re: MR_P_BODY] #425062
08/01/09 08:00 AM
08/01/09 08:00 AM
RIFF-RAFF
.RACING
How bout' Riff-Raff Racing(and occasional BSing)MUCH more appropriate!
Re: Shop Floor Coverings #425063
08/01/09 08:37 AM
08/01/09 08:37 AM
Epoxy is the way to go. I do them but it has to be done right. The stuff in the can from HD or Shermin Williams will not last. The floor has to be etched and done right and it will last for a min of 10yrs. Dura-bond is a great product.
Rob
Re: Shop Floor Coverings [Re: rowin4] #425064
08/01/09 08:50 AM
08/01/09 08:50 AM
I was thinking about putting sand in the clear coat,
I seen this done in the lab I worked in ... worked
well(I wont put as much as they did, made it sorta
hard to clean)
Rob
I was going to use a muriatic acid solution to prep
the floor... its new concrete but I have tire marks
and a little oil on it from the skid loader and
tractor from when I was putting up the iron
Page 1 of 3 1 2 3
