Re: Most you can take off 340-360 heads.
[Re: mark7171]
#424738
07/31/09 04:02 PM
07/31/09 04:02 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
the 587, 675 closed chambers, 915's are open i believe ? The 675's are 76 cc's. I believe not sure? my heads were milled about .065" to get around 60cc. What is the max millage?
The 051's already have a small chamber 58cc or something. Can't take off too much on a 051.
Non of the above are closed chamber heads. The 675 is a small 318 head Not closed chamber.. The 587 heads are the 340/360 heads used in 1973/74 up through in some cases 1976. Most OEM 915/587/596/974 CC'd in the area of 72 CC's. None of the above heads are closed chamber heads. I personally have seen one set at .125 and another at .140 off the face of SB 360 head and used successfully on a dirt track car. It did take some feness on the intake side though. I wouldn't recommend it. But as far as I know they are still going. When done they CC'd 48. I personally have gone .070 and gotten to 60 CC's.
[Re: MoparforLife]
#424739
08/01/09 01:38 AM
08/01/09 01:38 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The only factory closed chamber heads 315- and another 273 head I don't remember the number now came on 273s 64-66 they are typically about 60cc 920 was one year only head for both 273 and 318s in 67 then they went open chamber.920s are also about 60cc 302-714 85-91 318s used these, they are the high swirl head and run about 62cc And of course the magnum heads witch are all basically the same no matter the number and they are typically around 62cc
All other factory heads are open chamber cept mabey some oddball motor home head or industrial or something obscure like that.
Open chamber 340-360 heads are normally around 72cc and 273-318 open chamber heads are around 67cc.
Every ones deffnition of "too much off" is going to be different. Some people are OK if it lasts a season of drag raceing before they crack, some people want them to last forever, some people it is too much off if you have to mill the intake surface or if you get the intake side so thin it is hard to seal.
