cam and crank position sensors #424382
07/30/09 09:18 PM
07/30/09 09:18 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
can these sensors be removed and cleaned and re-installed, or is the only fix to replace them. Never fooled with them before, but my '01 300m is having difficult hot start problems. Lights off immediately on a cold start.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: cam and crank position sensors [Re: GO_Fish] #424383
07/30/09 11:03 PM
07/30/09 11:03 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They are 3 wire hall effect sensors and all you can do is replace them when they go bad. Now some models have adjustments for the air gap on the cam sensors that you had to get the sticky dot and put it on the cam sensor to adjust the air gap. Does it have any codes or a check eng lite on ? Ron
