Re: High dollar spark plugs...worth it?
[Re: OA5599]
#423767
07/30/09 11:09 AM
07/30/09 11:09 AM
Quicktree
[Re: OA5599]
#423768
07/30/09 11:14 AM
07/30/09 11:14 AM
Posts: 767 NW PA
V10nacuda
NW PA
If their performance gain claims are like their longevity claims. I SAY DON'T WASTE YOUR MONEY tried a good set of plugs in a dailey driver & they didn't last as long as the chumpions MY V10
[Re: HemiGreg]
#423773
07/30/09 12:23 PM
07/30/09 12:23 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Run away from the bosch plugs is my only real advice. We get a lot of cars where people install them there selfs and can not figure out why it started missing. Ocasionally we see that with autolites or champions and I have only seen an NGK do that one time even after working at a honda dealer for 3 years where they are factory installed so I use NGKs, not platniums just the regular old NGK.
[Re: BobR]
#423775
07/30/09 01:10 PM
07/30/09 01:10 PM
Posts: 202 Barboursville, VA
belvedere383
Barboursville, VA
I run the Autolite racing series plug, and they are awesome in my car.
65' Belvedere
496'' Stroker Indy Heads
Post deleted by Defbob
[Re: belvedere383]
#423776
07/30/09 01:28 PM
07/30/09 01:28 PM
#423777
07/30/09 01:35 PM
07/30/09 01:35 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
i ran some brisk plugs in a ss hemi on the dyno over ar51 autolites,,,,, 5hp difference in the minus direction,,, run autolites
[Re: moderncylinder]
#423778
07/30/09 04:32 PM
07/30/09 04:32 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
What Autolite plug would be the cross over for a Champion C59CX? I will give them a try,only using Champion because thats what Indy said use.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
#423780
07/30/09 04:49 PM
07/30/09 04:49 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I think that on any given pull there is often a 5 or more HP difference even with no changes. The Nickens test claims an improvement and you say you say you saw it go the other way. FWIW I'm with you and would trust the AR plugs over Brisk. On our deal we just want the plug to fire. 5 or ten extra HP out of the plugs means diddily squat to us. We've had a few dead holes for no apparent reason(nothing else wrong) over the course of this season and we were told that guys in the know use the AR plugs over the NGK's we were using. The next race we'll have the AR's on board.
