Clutch switch for a challenger #423440
07/29/09 10:49 PM
07/29/09 10:49 PM
moparfar Offline OP
moparfar  Offline OP
Where can I find a switch for the clutch the one that is need to start the car and ties into the the starter switch. It is for a 1970
Re: Clutch switch for a challenger [Re: moparfar] #423441
07/29/09 10:53 PM
07/29/09 10:53 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
I don't have one for sale, but here a picture of what you need. Missing wire.
Re: Clutch switch for a challenger [Re: Snoopy] #423442
07/29/09 11:02 PM
07/29/09 11:02 PM
Snoopy Offline
Snoopy  Offline
With wire.
Re: Clutch switch for a challenger [Re: Snoopy] #423443
07/29/09 11:05 PM
07/29/09 11:05 PM
Snoopy Offline
Snoopy  Offline
71 Clutch Safety Switch for comparison.
Re: Clutch switch for a challenger [Re: moparfar] #423444
07/29/09 11:12 PM
07/29/09 11:12 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
They are scarce and pricey..
Check with Wayne @ Brewers he has some clutch switches.
http://www.brewersperformance.com
The other alternative is to just ground the starter relay terminal...
Just my $0.025...
Re: Clutch switch for a challenger [Re: Sinitro] #423445
07/29/09 11:30 PM
07/29/09 11:30 PM
Snoopy Offline
Snoopy  Offline
I lot of people don't like using the switch because it requires you to depress the clutch pedal in order to start the car. This places a load on the crankshaft main bearing thrust surface when there may be a lack of proper lubrication, causing excessive wear. I am not convinced, but I don't count.
One work around is to permanently ground the starter switch and make sure you have the car in neutral before starting. Keep the switch for appearance.
Personally I feel that if a person doesn't know enough to place the transmission in neutral before starting, then they shouldn't own a car with a manual transmission.
Re: Clutch switch for a challenger [Re: Snoopy] #423446
07/30/09 07:41 AM
07/30/09 07:41 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Brewer's Performance has them.
Brewer's Performance Inc.
2560 South State Route 48
Ludlow Falls, Ohio 45339
Phone 937-698-4259
Fax 937-698-7109 24 hours
Hours 10 AM - 6 PM Monday-Friday
Jules
Re: Clutch switch for a challenger [Re: Snoopy] #423447
07/30/09 08:49 AM
07/30/09 08:49 AM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
I lot of people don't like using the switch because it requires you to depress the clutch peddle in order to start the car. This places a load on the crankshaft main bearing thrust surface when there may be a lack of proper lubrication, causing excessive wear. I am not convinced, but I don't count.
I agree. It's also one more piece of maddening old electrical to fail which can leave you temporarily stranded.
On any of mine I have permanently grounded the relay, but have used a green wire with the correct grommets and connectors to keep the factory appearance. Only by looking under the dash at the clutch pedal would one be able to tell.
Re: Clutch switch for a challenger [Re: YYZ] #423448
07/30/09 08:53 AM
07/30/09 08:53 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
So if I understand this correctly, the wire at my switch is coming off I could just ground it under the dash somewhere and I would be OK to go? So I could leave the connector under the hood and the grommet through the firewall.
Re: Clutch switch for a challenger [Re: gygeneral] #423449
07/30/09 09:15 AM
07/30/09 09:15 AM
YYZ Offline
YYZ  Offline
Yup.
You could actually ground it right at the relay if you wanted to...
Re: Clutch switch for a challenger [Re: YYZ] #423450
07/30/09 09:33 AM
07/30/09 09:33 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Yup.
Thanks, good tip.
Re: Clutch switch for a challenger [Re: YYZ] #423451
07/31/09 10:38 PM
07/31/09 10:38 PM
Morningside, Long Island
scatcity Offline
scatcity  Offline
So basically you just remove the switch wire at the relay, and run a new lead from the relay to under the dash and ground it to the dash? (Green wire and grommet of course)...And that's it? No switch needed?
Re: Clutch switch for a challenger [Re: scatcity] #423452
08/04/09 02:03 PM
08/04/09 02:03 PM
Snoopy Offline
Snoopy  Offline
Or you could replace the starter relay with a pre 70 relay that had the ground tab soldered to the case.
Re: Clutch switch for a challenger [Re: scatcity] #423453
08/04/09 02:46 PM
08/04/09 02:46 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Just make a 4" lead, 0.25" tab female terminal @ 1 end and terminal lug on the other. Slide the tab connector on the starter relay and ground the terminal lug under 1 of the starter relay's mounting screws..
Takes about 90 seconds..
Just my $0.025...
Re: Clutch switch for a challenger [Re: Sinitro] #423454
08/04/09 02:53 PM
08/04/09 02:53 PM
scatcity Offline
scatcity  Offline
Great info... I was unaware of this procedure.
