Unstable down track
#423080
07/29/09 04:35 PM
07/29/09 04:35 PM
Posts: 1,200 UK
602heavy
UK
Charger weighs around 4200lb without driver , used mickey thompson , good year & hoosiers slicks , seems the car feels like it's on ice mid track (28x10.5x15"), only time the car will handle is if i inflate the tyres to 15/16psi , which just spins it off the line , is there a tyre for heavier cars like the stiff sidewall? & will it help? , runs 10.6 @ 130mph , having to lift off the throttle mid track with tyre pressures below 14psi. Caltracs with monos & ranchero shocks , front shocks are standard. Thanks,
Re: Unstable down track
[Re: 602heavy]
#423081
07/29/09 04:40 PM
07/29/09 04:40 PM
Front end matters Stock suspension? Do you know how much positive castor you have? do you know how much it toes OUT ? PM me and I can help--I live near Herb McCandless and he has schooled me on front suspension stuff on all the drag cars I have had --I MIGHT be able to help DK
[Re: 602heavy]
#423082
07/29/09 04:48 PM
07/29/09 04:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Does the front dart around or does it feel like the rear is moving around. Have you done a toe curve checking to see if it goes toe out(not good, this causes the car to dart back and forth). What year charger, is it a fast back. They do make still side wall slicks
[Re: 602heavy]
#423083
07/29/09 04:50 PM
07/29/09 04:50 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Thanks,
I use the M/T ET streets (11.50/28/15- same as the (9 x 28 ET Drag slick ) at 18 lbs. Car weighs 3750 with me in it. I have Caltrac bars and QA-1adjustable shocks. Has run a best of 10.43@ 130.56 with no downtrack spin issues.
[Re: cudabunch]
#423086
07/29/09 06:11 PM
07/29/09 06:11 PM
Posts: 1,200 UK
602heavy
UK
68 charger
Toe in is 5mm , camber is zero & castor is maxed out , although i had to bring the UCA forward around 1/2" in order to get zero camber , but still got positive castor.
Tried a few tyres so thinking it's not down to sidewall wear , maybe 90/10 shocks would help out?
What application would the stiff sidewall tyres be used on? , is this for heavy cars?
[Re: 602heavy]
#423087
07/29/09 06:19 PM
07/29/09 06:19 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
my car was like that. went to radials and its great
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#423088
07/29/09 09:05 PM
07/29/09 09:05 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
too much pre load on the cal tracs will cause that start backing them off 1/2 turn at a time! Made a huge difference in mine when I had a 542 (RIP) added some extra pre load last time out with my 452 and it was way less stable top end. Just something to try
[Re: Dodgem]
#423090
07/29/09 10:24 PM
07/29/09 10:24 PM
Posts: 1,200 UK
602heavy
UK
Only got 1/2 turn preload on the bars , would this make a difference? , thinking too much preload would be similar as having to hard a shock absorber? , never driven it without preload so will be interesting to see what happens , fitted them & set them up as per caltracs instruction.
[Re: 602heavy]
#423091
07/29/09 10:48 PM
07/29/09 10:48 PM
Dodgem
Ontario, Canada
When I went to the 542 (RIP) from the 452 I had to go to 1 to 1 1/2 turns of negative from 1 turn pre load with my 452. now I'm back to 1 turn pre load with a 452 tried 2 turns of pre load last time out and it felt unstable top end and moved around a bit!! Then an oil leak ended my week end! Calvert told me if it feels unstable and moves around to loosen bars as too tight does not let the suspenion work I assume you have a big incher that makes it act too tight. on mine it did anyways.
[Re: 602heavy]
#423093
07/30/09 12:10 AM
07/30/09 12:10 AM
Dodgem
Ontario, Canada
Yea I tried to leave it where it was good for the 452 and eventually started taking load out and it got better and better. launch and down trac. after blowing up the 542 another 452 and it likes pre load??? all you can do is try things. The TT night with the 542 when I went back first 1 turn then 2 the 1/2 a guy from Detroit stopped by and help watched saying they went through the same thing with a big inch and monos and cal tracs?? Just what happened to me!! I had made up my mind the pre load was too much for all that torque (and cal had said I might have to start going back and see if it liked it) I made a TT then took 1 turn smoother launch and easier drive. then took another the 1/2. dam then it left smooth pulling the wheels 4 to 6 inches and carrying them 20 to 30 feet then straight down broadway!! I never ran any faster 60 foot or 1/4 but it was way smoother all round. But if your driving all over that can't be good!!!!
