Re: 37 Degree flare on aluminum fuel line for AN fitting ?
[Re: 69MOPE]
#422932
07/29/09 01:06 PM
07/29/09 01:06 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
you need to use a 37 deg flare tool
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 69MOPE]
#422936
07/29/09 01:33 PM
07/29/09 01:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Or you could go with a compression fitting to AN. Or you use the standard flair kit but when you use the double flair button you dont press it all the way down leaving a much shallower flair... works well
[Re: MR_P_BODY]
#422937
07/29/09 01:36 PM
07/29/09 01:36 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I used the compresion style tube end adapters from summit. They work great.
[Re: WILD BILL]
#422938
07/29/09 02:05 PM
07/29/09 02:05 PM
Posts: 1,880 USA
Ron Silva
USA
Rigid makes a very nice tool. That is the one I use. Slide on a tube nut and a sleeve, flare and you are done. Their tool makes awesome flares.
ALL my FUEL and TRANS hard lines on my car are aluminum.
SRT DEMON ONE SEAT
[Re: WILD BILL]
#422939
07/29/09 02:17 PM
07/29/09 02:17 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Watch the connections on aluminum tubing when using compression type fittings. They have a tendency over time to crack the tubing around the ferrules.The compression ring can act like a saw and eventually cut into the tubing. Something to be aware of. A flared fitting in my opinion is much better and safer in a race car.
RIP Monte Smith
[Re: CompWedgeEngines]
#422942
07/29/09 07:28 PM
07/29/09 07:28 PM
WILD BILL
BROOK PARK, OH
So far I haven't had a problem with them but thanks for the information. I will try to remember this if/when the time comes and repair it accordingly.
