37 Degree flare on aluminum fuel line for AN fitting ? #422931
07/29/09 01:00 PM
07/29/09 01:00 PM
Ridley Park, Pa.
69MOPE Offline OP
super gas
69MOPE  Offline OP
super gas
Ridley Park, Pa.
How do you guys flare aluminum fuel line to attach AN sleeve and fitting? I believe it is 37 degrees.
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: 69MOPE] #422932
07/29/09 01:06 PM
07/29/09 01:06 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
you need to use a 37 deg flare tool
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: dusturbd340W5] #422933
07/29/09 01:23 PM
07/29/09 01:23 PM
Ridley Park, Pa.
69MOPE Offline OP
super gas
69MOPE  Offline OP
super gas
Ridley Park, Pa.
Who sells them?
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: 69MOPE] #422934
07/29/09 01:27 PM
07/29/09 01:27 PM
I bought a 37 degree flaring tool from Parker hydraulic company, not cheap but it does work excellent I have heard of some racers using a 45 degree flaring tool and not flaring the line out all the way to 45 degrees, they would quit at about 30 degrees, they then used the tubing nut and the male end of the other fitting to finish the seating of the line. That will probally work fine on soft aluminum lines but not worth a hoot on hard drawn aluminum tubing ,stainless or regular steel lines
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: Cab_Burge] #422935
07/29/09 01:30 PM
07/29/09 01:30 PM
Kissimmee Fl.
Kissimmee Fl.
I got a cheap 1 from summit that works just fine
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: 69MOPE] #422936
07/29/09 01:33 PM
07/29/09 01:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Or you could go with a compression fitting to AN.
Or you use the standard flair kit but when you use
the double flair button you dont press it all the way
down leaving a much shallower flair... works well
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: MR_P_BODY] #422937
07/29/09 01:36 PM
07/29/09 01:36 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I used the compresion style tube end adapters from summit. They work great.
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: WILD BILL] #422938
07/29/09 02:05 PM
07/29/09 02:05 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Rigid makes a very nice tool. That is the one I use. Slide on a tube nut and a sleeve, flare and you are done. Their tool makes awesome flares.
ALL my FUEL and TRANS hard lines on my car are aluminum.
SRT DEMON ONE SEAT
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: WILD BILL] #422939
07/29/09 02:17 PM
07/29/09 02:17 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Watch the connections on aluminum tubing when using compression type fittings. They have a tendency over time to crack the tubing around the ferrules.The compression ring can act like a saw and eventually cut into the tubing. Something to be aware of. A flared fitting in my opinion is much better and safer in a race car.
RIP Monte Smith
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: Ron Silva] #422940
07/29/09 02:32 PM
07/29/09 02:32 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
This is the one I use. I like it because it "ROLLS" the flare into the tube.
http://www.toolup.com/ridgid/41162.html#
SRT DEMON ONE SEAT
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: Ron Silva] #422941
07/29/09 06:53 PM
07/29/09 06:53 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Ordered one of those last week . Will be on my porch tomorrow!
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: CompWedgeEngines] #422942
07/29/09 07:28 PM
07/29/09 07:28 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
So far I haven't had a problem with them but thanks for the information. I will try to remember this if/when the time comes and repair it accordingly.
Re: 37 Degree flare on aluminum fuel line for AN fitting ? [Re: WILD BILL] #422943
07/30/09 07:07 AM
07/30/09 07:07 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
I turned a 37 degree button on my lathe and used that with my regular flaring tools.
