Leaving with a 4 speed??
#422798
07/29/09 09:42 AM
07/29/09 09:42 AM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Im very new on racing at the track, I have only raced a car on a prepped track a few times and that car had BFG radials on it, it DIDNT HOOK period. I have a centerforce clutch and the demon has Mickey Thompson drag radials on it, it hooks way better. It also has a pinion snubber, and Super Stock springs, and QA1 shocks. Do I roll through the water, and burn off the water, or do a good burn out. I realy dont feel like A, breaking anything, and B destroying my clutch. Its got 3:91 gears, and 295 60 15 tires. It hoods quite hard on just plain highway after a good burnout by reving to 3500 and driving through, then launches hard, Im just nervous of hurting something.
thanks guys..
Kasey
Re: Leaving with a 4 speed??
[Re: MR_P_BODY]
#422802
07/29/09 10:37 AM
07/29/09 10:37 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
In a hurry..... you gave it all of 20 minutes
give it some time a few of us still have JOBS during the day.theres a bunch o good rowers on this board im sure theyll respond in time.OH, buy the way dont worry about breaking somthing on a good hooking trak,ITS GUNNA HAPPEN.
[Re: wheelsup68dart]
#422804
07/29/09 10:48 AM
07/29/09 10:48 AM
Posts: 637 Sao Paulo, Brazil
dart_73_br
Sao Paulo, Brazil
Do you have a driveshaft loop? Hope your tech is leinient. Around here if you have drag radials you must have loop.
Do you think itīs very necessary !? To prevent from beeing killed !?
I donīt have... thinking of it...
[Re: MR_P_BODY]
#422806
07/29/09 10:56 AM
07/29/09 10:56 AM
Moparnut426
Sorry guys, not in a hurry, just dead in the shop, and it seems like its been 6 hrs already...
[Re: emarine01]
#422807
07/29/09 10:58 AM
07/29/09 10:58 AM
Moparnut426
Humm, Drive shaft loop, that came to mind just after good u joints and checking back lash
I have a new fast shaft on order from the local race shop in town, and Im upgrading to 7290 u joints also.
Thanks guys...
[Re: 9 Sec Phill]
#422809
07/29/09 08:33 PM
07/29/09 08:33 PM
Posts: 904 cleveland Ohio
mloboda
cleveland Ohio
Everything you always wanted to know about 4 speeds but were afraid to ask is on the www.umtrnorth.com forums. This is a website dedicated exclusively to the lost art of stick shift drag racing. Check it out !!!
[Re: mloboda]
#422810
07/29/09 08:46 PM
07/29/09 08:46 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Here is my take on it. I used to race a 4-speed 340 Dart that ran low 12's and high 11's. I used 4.56 gears and 29" tires and I felt that if I am racing with a stick car I want to launch it as hard as I can with some hook. On 9" slicks and SS springs I would bring it up to about 6000 and on the third yellow pop the clutch and floorboard the gas pedal. It would hook fine on a decent track but it was hard on the driveline. I hate to see a stick car launch at 2500 and then just bog down because you know it dont have enough gear. Thats just my take as I like to have it on the floor when the clutch comes out. Thats why my 63 is an auto because it leaves as hard as a stick would in it but it dont break driveline parts like a stick car as the driveline is already loaded when you floor it. Good luck , Ron
[Re: Moparnut426]
#422811
07/29/09 09:30 PM
07/29/09 09:30 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Whats your low gear in the trans? If you have a 2.65-2.66 gear then I would suggest a 4.10-4.30 gear to keep the clutch alive launching with traction.The best way to leave when you have marginal to little traction and you don't want to just "let it fly" then you will compromise the life of your clutch by slipping it to keep from bogging.I say let it fly and adjust tire pressure until you start breaking driveline parts then replace as needed with stronger stuff Then if you cant handle that then don't race it or put an automatic in it There really is no "perfect" magic set-up for good bite and long clutch life in a street/strip car.There has to be slip somewhere so I suggest tires Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
