8.5:1 340 slightly perked up, cam, headers, RPM intake, holley 750 dbl pump. seems to be a bit rich going by tailpipe odor and appearance, plugs are on the brown side not black but not white. Am I going to help or hurt performance by going more lean? At the track the car ET's better as the air temp cools, perhaps this is typical, but the motor does appear to be rich going by observation noted above. Tried a 650cfm holley and it seriously hurt botton and mid range, put 750 back on, runs better but seems a bit rich, so should i tweak on the 750 or 650? Another thing to note, is that at the Classics I started out doing my burnout with secondaries and ran 13.50s. I tried doing my burnout with primaries only and dropped to 13.20s...all of that gained in the 60ft and 330. Right now my jetting is 73 primary and 76 secondary. I have been told my numerous people that the 750 is too much, but I have tried a really good Holley 650 and a 600 Eddy and even after some tuning neither one would come close to the 750. If you need more info, just ask. Any input would be greatly appreciated.
