Burnouts with no line lock?? - 4 wheel discs
#422623
07/29/09 08:43 AM
07/29/09 08:43 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hey guys - Trying to keep my car simple and stock as possible, but I do plan on racing it every now and then. Maybe a few times a year...Anyhow, my concern is that the car has 4 wheel discs. How easy/difficult/dumb will it be to do a burnout without a line lock? Thanks
2 kids and a dog
Re: Burnouts with no line lock?? - 4 wheel discs
[Re: nosboy]
#422626
07/29/09 08:59 AM
07/29/09 08:59 AM
Posts: 8,165 Left Coast
BobR
Left Coast
bad idea.. Get a line lock.. You really dont want to burn up your rear disc brakes.. DO YOU???
I have to agree with this. You will glaze your rear brakes making them less effective.
[Re: MegaDart]
#422629
07/29/09 10:10 AM
07/29/09 10:10 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
4 wheel Aerospace brakes here been running it for three years with no line lock running two classes a night. Zero problems.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#422630
07/29/09 10:17 AM
07/29/09 10:17 AM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Our street car has 4 wheel discs and no line lock. Been that way since 2000 and not any issues at all. FWIW the car in question runs mid 10's.
[Re: TonyS451]
#422632
07/29/09 03:30 PM
07/29/09 03:30 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Most cars truly don't need a line lock anyway. If you roll through the puddle and stop just before the pavement gets dry and smack the throttle hard, the car will jump right up on the tire with very little forward movement, even with no line lock. As soon as it starts spinning well, go to high gear to make wheel speed and you will get the tire plenty hot, plenty fast and hardly move forward. Regardless of tire type, or how you see some kill their tires in the burnout, the ideal tire temp is within 20-30 degrees of the track temp. The only time I have ever used the line lock on any of my cars, was if it had a clutch and then I used it to stage. May take you a few times to get used to this method, but it's really easy once you do.
Monte
