need help removing harmonic balancer #422413
07/28/09 10:51 PM
07/28/09 10:51 PM
Kansas
maxwell wedge Offline OP
Kansas
This is a stupid question but I just bought a 73 dart and need to replace the timing chain but can't get the harmonic balancer bolt to budge without turning over the motor. What am I doing wrong?
Re: need help removing harmonic balancer [Re: maxwell wedge] #422414
07/28/09 10:55 PM
07/28/09 10:55 PM
In a van, down by the river
jmf340 Offline
jmf340  Offline
You need a friend to hold the motor while you loosen the bolt.
Got Mopar???
Re: need help removing harmonic balancer [Re: jmf340] #422415
07/28/09 10:57 PM
07/28/09 10:57 PM
Kansas
Kansas
Or maybe I should have the friend hold the wrench while I turn the motor? LOL!
Re: need help removing harmonic balancer [Re: maxwell wedge] #422416
07/28/09 10:59 PM
07/28/09 10:59 PM
jmf340 Offline
jmf340  Offline
If the radiator is out, you may be able to get an impact wrench in there to loosen the bolt.
Got Mopar???
Re: need help removing harmonic balancer [Re: jmf340] #422417
07/28/09 11:04 PM
07/28/09 11:04 PM
Kansas
Kansas
Yeah its out, but I have no impact wrench at my disposal.
Re: need help removing harmonic balancer [Re: maxwell wedge] #422418
07/28/09 11:06 PM
07/28/09 11:06 PM
jmf340 Offline
jmf340  Offline
Okay, so get a friend to hold a wrench on a torque convertor bolt while you use a breaker bar and a 1 1/4" socket to loosen the bolt. Or you can wedge a wrench against a header and do it by yourself.
Got Mopar???
Re: need help removing harmonic balancer [Re: jmf340] #422419
07/28/09 11:20 PM
07/28/09 11:20 PM
Kansas
Kansas
Alright I will try that. Thanks for your help.
Re: need help removing harmonic balancer [Re: maxwell wedge] #422420
07/28/09 11:45 PM
07/28/09 11:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Put a ratchet on the bolt and hit it with a hammer in the direction to loosen the bolt. I found the shock of being hit my the hammer did more than force with a breaker bar.
Re: need help removing harmonic balancer [Re: DaytonaTurbo] #422421
07/29/09 12:19 AM
07/29/09 12:19 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Another idea is to use a breaker bar setup and wedge it against the frame and tap the starter and it should break the bolt loose when it turns over. I did this years ago on my 70 Barracuda with a 318 it worked pretty well.
Re: need help removing harmonic balancer [Re: maxwell wedge] #422422
07/29/09 12:31 AM
07/29/09 12:31 AM
AndyF Offline
AndyF  Offline
Just buy the tool to hold the damper.
http://chucker54.stores.yahoo.net/damperholder.html
