09 Challenger lowering kit #421817
07/28/09 04:28 PM
07/28/09 04:28 PM
Tacoma, Wa.
danbs23 Offline OP
danbs23  Offline OP
Tacoma, Wa.
I want to lower my 09 Challenger 2" and I'm not sure which springs will give the best ride. The car rides like a dream now I and want to keep as much of that as possible. What do you guys think?
Re: 09 Challenger lowering kit [Re: danbs23] #421818
07/28/09 04:33 PM
07/28/09 04:33 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It's going to get a lot stiffer. That may or may not be a good thing. It all depends on what you concider to be too harsh.
I installed Intrax 2" lowering springs on my 02 Stratus R/T. The look was great and the handling was improved a bunch. The ride was quite a bit harsher though. I liked how if felt but others probably wouldn't.
Re: 09 Challenger lowering kit [Re: danbs23] #421819
07/28/09 05:47 PM
07/28/09 05:47 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
You can use springs(eibach/ hotchkis) or coil overs( M/P,KW,eibach or others). If you go with just springs it a good idea to use their struts, if you go w/ coilovers then you have ride ht. adjustability. You can also check out www.lxforums.com theres a lot of posts on lowering over there,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
