Carburater tuning #421699
07/28/09 12:25 PM
07/28/09 12:25 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
What is the quickest and easiest way to tune a carb and get it right (or atleast real close) for your setup? I have a 750 with 78/80 jets, 26 and 31 squriters and not sure of the cams on the carb. I purchased a new 850, put 80 squared jets, put 26 and 31 squirters and it seems to have a stumble to it now? Motor is a standard bore 440 with 440 source alum heads, .533 mopar performance cam, weiland single plane intake, running on 93 octane pump gas. Also for some dumb reason holley has changed their accelarator pumps from the old ball valve to the new rubber seal and they seem to work like junk.
Re: Carburater tuning [Re: DusterKid] #421700
07/28/09 01:24 PM
07/28/09 01:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Tell us about the power valve/valves front and back none??
Re: Carburater tuning [Re: Dodgem] #421701
07/28/09 01:39 PM
07/28/09 01:39 PM
Keymar, MD
Keymar, MD
Both carbs do not have a power valve in either the front or the back, a power valve plug is installed.
Re: Carburater tuning [Re: DusterKid] #421702
07/28/09 02:22 PM
07/28/09 02:22 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Do you think it makes sence to use the same main jets on a carb with different flow?
I dont.
Besides isnt the 850 supposed to come with 80 main jets with power valve?
That means your carb is probably lean.
Re: Carburater tuning [Re: sshemi] #421703
07/28/09 02:36 PM
07/28/09 02:36 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
Sounds lean to me on that carb also. Try 84's (if blocked PV's), and 31 squirters both ends. Personally, I'd try the 80's in front with 4.5 PV It's been my experience that the diaphram check valves are actually more reliable than the check balls with today's fuel. Make sure that fuel is squirting in venturi's as soon as throttle is moved at all, accel pump adj, etc.
Re: Carburater tuning [Re: DusterKid] #421704
07/28/09 03:28 PM
07/28/09 03:28 PM
Cab_Burge Online work
Cab_Burge  Online Work
Two things you need to do for us to help you, what is the List number of the new 850, IE 4781-? or ??????? and what manifold vacume(not ported, vacume under the butterflys on the carb) do you have idling in gear? The Squirters sizes do sound a little on the small size unless you live where the elevation is above 4500 above sea level
Re: Carburater tuning [Re: Cab_Burge] #421705
07/28/09 03:31 PM
07/28/09 03:31 PM
sweden
sshemi Offline
sshemi  Offline
sweden
A good thing is to check the list nr like cab said and look it up on Holleys website and jet it the way it came from them.
They usually arent that far off when on a mild engine (from being ok that is not perfect).
Re: Carburater tuning [Re: sshemi] #421706
07/28/09 03:46 PM
07/28/09 03:46 PM
Keymar, MD
Keymar, MD
The carb is a Holley 9380 850 cfm. It came with 78 jets front and rear, and 31 squirters front and rear. It also had a power valve in the front and rear, not sure what they were, but I took those out and plugged them since I never have any luck with power valves. I've adjusted the idleling screws, checked the float levels and added jet extensions with the jet extension float to the rear bowl. With 78/80 in the 750 the car worked great, but seemed to be a little rich, so thats why I didn't upsize jets in the 850. I did have 80/85 in the 850 and it wouldn't idle worth crap.
Re: Carburater tuning [Re: DusterKid] #421707
07/28/09 04:00 PM
07/28/09 04:00 PM
Try starting with 84 jets square with no power valves and see how that works. I like and use power valves in all of the Holley carbs that I own and use that came with them The big thing on power valves is to use a power valve that is rated to open at least one or two inches under the idle RPM in gear, such as if it idles at 6.0 inches in gear I would use a 4.5 or a 3.5 rated power valve There are some "carb" guru on this site will tell you that the power valve circiut has nothing to do with the idle vacume , WRONG Try using a smaller vacume rated power valve in your carb( check the idle vacume and go lower) and go back to the stock jetting and see how that works, let us know if you do and the results
Re: Carburater tuning [Re: DusterKid] #421708
07/28/09 04:02 PM
07/28/09 04:02 PM
sweden
sshemi Offline
sshemi  Offline
sweden
The main jets have absolutly nothing to do with the idle system.
And if it changes when you change MJs that means your throtle blades are opened too much so you are already in the main system.
Make sure the blades are set correctly.
And if i where you i would use a power valve in front and jet it 78 front and ~86 rear
Re: Carburater tuning [Re: sshemi] #421709
07/28/09 05:25 PM
07/28/09 05:25 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
I'd put the 31 squirter back in the front also.
Re: Carburater tuning [Re: DusterKid] #421710
07/29/09 11:47 AM
07/29/09 11:47 AM
New York
polyspheric Offline
polyspheric  Offline
New York
I took those out and plugged them since I never have any luck with power valves.....
Boffin Emeritus
