Re: Points to Electronic ?
[Re: beatupcuda]
#421542
07/28/09 08:42 AM
07/28/09 08:42 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
MSD Pro Billet hands down . Use the 7AL for race , or 6 AL for street / mild race. IMHO Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: MoparforLife]
#421547
07/28/09 12:45 PM
07/28/09 12:45 PM
Posts: 10,212 Someplace you aren't
SomeCarGuy
Petronix makes some really good products. I have used them several times. Not in recent years though. Pretty stealth if you want it to look stock.
I want my fair share
[Re: Dodgem]
#421548
07/28/09 02:08 PM
07/28/09 02:08 PM
Posts: 209 Arkansas
beatupcuda
Arkansas
Thanks, I have read on these Items, just wondered about, MP parts, I see, orange, black, & chrome boxes, possibly making more or less available rpm limits, I thought my dual point, and Mopar perf coil would do the job, except I have been told it's probably going south about 4000 rpm, in the early 70's this seemed to work just fine. I do like msd, but really only need 7000 limit, and have just about spent all my $$$ on this 426 hemi already.
68 Hemi 4 speed Cuda,,,,building ?
[Re: SomeCarGuy]
#421553
07/28/09 10:23 PM
07/28/09 10:23 PM
DaytonaTurbo
Manitoba, Canada
Pertronix or a ProComp ready to run distributor. They can be had for $50-70 off that auction site. Why clutter up a nice hemi engine bay with all the wiring/electronics of the stock chrysler system? Keep it all in the distributor so it stays neat, tidy and clean.
[Re: Dodgem]
#421558
07/29/09 03:48 PM
07/29/09 03:48 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Well with were you are going 6000 to 6500 probably mostly cruising why not MP. I still not fussy on vacuum advance. I once cut the arm off welded the plates together and left pot on heck you could block the vacuum line and put it on ported vacuum of carb so it looks stock!
[Re: Dodgem]
#421563
07/30/09 08:00 AM
07/30/09 08:00 AM
Posts: 209 Arkansas
beatupcuda
Arkansas
Hey gang ! I have a stock dual point now, w/tach drive, which I would rather convert vs buy something new, but all I have seen is single points dist conversions, so maybe for both , just change the plate & shaft ? and Dodgem,,,my 770's have no vac port anyway, this is the main reason I do not / cannot have a vac adv, no where to hook it up, without going into the manifold or custom fitting into a carb.
[Re: Tom Hand]
#421565
07/31/09 08:09 AM
07/31/09 08:09 AM
Posts: 209 Arkansas
beatupcuda
Arkansas
Thanks, but no, I think once I see the parts, it would be no problem to do, thanks. Probably should throw my dually into a box with the coil, & wires to put back on once it's for sale for originallty,,,, but that's wayyyy down the road, thanks everybody here for the help.
