Re: Points to Electronic ? [Re: Tom Hand] #421561
07/29/09 08:08 PM
07/29/09 08:08 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
And this with cap on.
Re: Points to Electronic ? [Re: Tom Hand] #421562
07/29/09 11:02 PM
07/29/09 11:02 PM
Tom you converted an OE prestolite dual point unit to OE electronic
Re: Points to Electronic ? [Re: Dodgem] #421563
07/30/09 08:00 AM
07/30/09 08:00 AM
Arkansas
beatupcuda Offline OP
Arkansas
Hey gang !
I have a stock dual point now, w/tach drive, which I would rather convert vs buy something new, but all I have seen is single points dist conversions, so maybe for both , just change the plate & shaft ?
and Dodgem,,,my 770's have no vac port anyway, this is the main reason I do not / cannot have a vac adv, no where to hook it up, without going into the manifold or custom fitting into a carb.
Re: Points to Electronic ? [Re: beatupcuda] #421564
07/30/09 10:23 PM
07/30/09 10:23 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
RRobert, actually a friend of mine did it. I am not that talented.
68, you want his name to see if he can convert yours so you can use your tach drive still?
Re: Points to Electronic ? [Re: Tom Hand] #421565
07/31/09 08:09 AM
07/31/09 08:09 AM
Arkansas
Arkansas
Thanks, but no, I think once I see the parts, it would be no problem to do, thanks.
Probably should throw my dually into a box with the coil, & wires to put back on once it's for sale for originallty,,,, but that's wayyyy down the road,
thanks everybody here for the help.
