Re: Best disc brake set-up for the the buck...
[Re: dcoronet383]
#421007
07/28/09 12:07 AM
07/28/09 12:07 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Could try these if you want a kit but they are kind of expensive www.mpbrakes.com or www.ssbrakes.com
I don't see either of those choices as the best for the buck... & FWIW I really hate the look of the GM Master Cylinder & Booster that they use....
[Re: 1_WILD_RT]
#421008
07/28/09 12:49 AM
07/28/09 12:49 AM
Posts: 18,157 Mass
DAYCLONA
Mass
You don't even want to waste your time or $$$ with the MP set up, SSBC makes some nice upgrades, if you go that route, invest in the best upgrade you can afford,....BUT, there's nothing wrong with using factory componets, if you can't find vintage B,E set ups, the A is the best next choice, along with the F/M/J spindles, caliper brackets can interchange amongst most of the knuckles, if the pin calipers are desired, you must be selective in where you mount the calipers in relation to swaybar links, bleeder height location, hose length, clearance issuses, proportion valve use, master selection, etc,.....when in doubt about the componets you may choose, check with the Moparts members, many skilled/experienced members to assist you in advoiding some pitfalls,....and keep in mind, simply buying a new "bolt-on" kit, dosen't assure you of trouble free installation .......don't be afraid of mixing factory componets either, just question if in doubt, better safe than sorry
Mike
[Re: 1_WILD_RT]
#421009
07/28/09 01:54 AM
07/28/09 01:54 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
11.75 rotors on 73-76 A body spindles....
I just checked www.rockauto.com and got some prices on the new stuff...
11.75" Rotors: $60 each new inner,outer bearings & seal: $18/side new Spindles with sheilds and 10.75 caliper adapters: $150-$200 pr for 73-76 A-body and $100-$150 for FMJ-body used Calipers: $45-$60 each with pads $60 w/semi metalic pad new rebuilt 11.75 caliper adapters: $60-$100 used caliper hoses: $60-100 pr braided new, $25 pr rubber new disk master: $65 new rebuilt adjustable proportioning valve: $45 (Mancini) new
I come up with $661 for all that. Minus $50+ if you use FMJ spindles. Minus $100 if you use $10.75 disks
For an A-body you will need some used upper control arms and lower ball joints.
[Re: AndyF]
#421011
07/28/09 09:32 AM
07/28/09 09:32 AM
Posts: 19,953 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
I did the 11.75 swap on my 71 Scamp using 73-76 A-body spindles. I used all new NAPA stuff, including non-Chinese rotors, got an E-berg aluminum MC, a Magnum HP adapter and heat shield, and a boneyard prop valve from a 73-76 A-body, boneyard slider caliper adapters from a 78 Cordoba. Cost me about $700 total, and the car stopped on a dime.
Earning every penny of that moderator paycheck.
DBAP
[Re: 70Challengerse]
#421014
07/28/09 12:24 PM
07/28/09 12:24 PM
Posts: 553 DE
Ply72rr
DE
[Re: AndyF]
#421017
07/28/09 04:23 PM
07/28/09 04:23 PM
Posts: 7,506 Az
Crizila
Az
Switching from 4 whl drum brakes to disc / drum has been a very popular upgrade for years. IMO, the mod is way over-blown. The original and main reason for the mod was brake fade with multiple brake applications - mainly due to poor quality brake shoes. The issue of poor quality brake shoes has been addressed long ago, and unless you are doing some major towing or sports car type racing, you will never realize the expenditure. Take a 1/4 of the $ and upgrade your existing brake system with some quality semi or full metalic shoes and new drums and you will have all the braking you will ever need. Take the rest of the $ and put it in the motor, or some area that you can actually enjoy.
Fastest 300
[Re: Crizila]
#421018
07/28/09 04:49 PM
07/28/09 04:49 PM
Posts: 2,255 IL
furious70
IL
How about the Summit kits, are they junk?
70 Sport Fury 68 Charger 69 Coronet 72 RR
