Made it to the Q16 finals yesterday, now with vid #420733
07/27/09 06:45 PM
07/27/09 06:45 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Let me start out by saying that this is airport racing. Traction was good for guys running true slicks. Drag radials were ok too. And it was scorching HOT! 95 plus I am sure.
This was my first time out with the Caltrac setup. Mono leafs and Rancho 9 way shocks. I left a little gap on the driver's side, and a little preload on the pass side. Shocks on 5. Car ran straight anyhow. Just a little stumble at the top of first gear. Think I am gonna try some jet extensions to see if that will clear that up.
Best run was a 7.3 at 96 MPH. 1.63 60'. This is 1/8th mile too btw.
I was the last qualifier for the Q16.
First run against a rail. He red lit.
Second run against a nasty Vega. He broke out.
Third run against a gorgeous Cuda. He broke out.
THEN in the final run, I was up against a Nova. This guy has been running this car for years. I think I heated the drag radials too much. No traction what so ever. I ended up with a 2.1 60', and lost it there. But runner up paid $300, so I was tickled pink. Only Q 16 qualifier to drive the car to the track too
I need to get to a real track soon to get the Caltrac set up tuned properly, but all in all, it was a great day.
codfish
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: codfish] #420734
07/27/09 07:15 PM
07/27/09 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Congrats The extensions wont help your issue,
look at the supply
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: MR_P_BODY] #420735
07/27/09 07:50 PM
07/27/09 07:50 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Thanks.
Don't think so?
It keeps pulling hard after the car settles down.
codfish
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: codfish] #420736
07/27/09 08:06 PM
07/27/09 08:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks.
Don't think so?
codfish
Well you said the top end of first gear... the extensions
are good for the launch.... try them, they're cheap
and it might help... you never know
EDIT
I would check the float level first
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: MR_P_BODY] #420737
07/27/09 08:32 PM
07/27/09 08:32 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
The floats have the fuel just trickling out the sight holes at an idle. I think I'll try the extensions. Like you said, they're cheap.
Regulator set at 7 psi, and an Aeromotive pump. Bigs stage 3 Holley 850DP.
Thanks Mike.
codfish
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: codfish] #420738
07/27/09 08:47 PM
07/27/09 08:47 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
Mike , how much air in your tires. I used to have 16.5 , 17 , than 18.5 lbs. would get traction most of the time but when it was an important run it would feel like I was running over the tires. This pass weekend I put it up to 20,5 lbs , hooked every time . My Dart is very similar to yours . Shocks at 9 , caltracs same adjustment as yours , 1.50 60'.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: codfish] #420739
07/27/09 09:07 PM
07/27/09 09:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks Mike.
codfish
Try the extension.... sure cant hurt... again congrats
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: caper] #420740
07/27/09 10:29 PM
07/27/09 10:29 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
He's Mike.
Actually I started with 20lbs, then tried dropping it to 18, and it spun. Ended back to 20 1/2 also, and it seemed happier there. A test n tune day is in order.
BTW, love that pic of your Dart.
gary/codfish
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: caper] #420741
07/27/09 11:05 PM
07/27/09 11:05 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
What size Drag Radials are you running?
Old Geezer Racing
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: SCATPACK 1] #420742
07/27/09 11:10 PM
07/27/09 11:10 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
325-50-15s MTs
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: codfish] #420743
07/28/09 12:49 AM
07/28/09 12:49 AM
Saskatchewan, Canada
barracudabob Offline
You gotta bring it to SIR August 8. There will be a test and tune, as well as Fastest Street Car Shootout. You should be able to get in several passes. Its 1/4, but you should be fine. It will be worth the drive. Aug 9 is a points race, you can stay and get in some more passes. You can look it up at www.racesir.com Bob
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: barracudabob] #420744
07/28/09 10:36 PM
07/28/09 10:36 PM
Newfoundland
codfish Offline OP
codfish  Offline OP
Newfoundland
Bob I'd LOVE to, but I gotta work. Only weekend I'm off is during Minot's last point race. Gonna hafta make that one.
Here's a pi$$ poor vid of the semi final pass.
http://www.youtube.com/watch?v=EkggjLaDxTI
codfish
Re: Made it to the Q16 finals yesterday, with lots o luck! [Re: codfish] #420745
07/28/09 10:41 PM
07/28/09 10:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I love videos!! that was cool!!
