Hi I have a 71 cuda with a 6.1 fuel injected 5 speed I use a mopar performance oil pan the K frame is an Alterktion with coil over the problem I got is that the oil pan is very low 21/2 " from the ground the pan is alumimium can I use a different pan and pick up from a 5.7 truck thanks Francis.
