340 in a boat #420579
07/27/09 03:29 PM
07/27/09 03:29 PM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
I found a parts boat with a 340 in it and was wondering if it's worth buying to use the engine in a car. I know most of the 440 engines in boats rotate in the oposite direction, but is that just a matter of replacing the crank?
Re: 340 in a boat [Re: repad] #420580
07/27/09 04:14 PM
07/27/09 04:14 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Well yes and no... the crank is less of a problem than the cam and gears..they have to be changed to a standard rotation ( car ) cam and gears..the crank can be used if you have a machine shop grind ( polish )off the nearling by the rear seal..another problem is if it was used in salt water..A serious corrosion problem there..And not all marine engines turn reverse...A stern drive motor is the same rotation as a car.. only single engine inboard and the right motor in a twin engine inboard powered boat. rotate reverse rotation .A lot of the mopar engines were used by Volvo penta and were used with stern drives and are standard rotation,,even the twin engine boats with stern drives are both standard rotation
Re: 340 in a boat [Re: dynamite] #420581
07/27/09 04:19 PM
07/27/09 04:19 PM
N.E Indiana
repad Offline OP
super street
repad  Offline OP
super street
N.E Indiana
Thanks,
I'm not a boat person so bear with me. If the motor is not running, how can I tell if it is car rotation or otherwise?
Re: 340 in a boat [Re: dynamite] #420582
07/27/09 06:15 PM
07/27/09 06:15 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
If it has been in salt-water without a heat-exchanger,just pass on it.If a heat exchanger was used it might justify further investigation.
Re: 340 in a boat [Re: solidcam] #420583
07/27/09 06:58 PM
07/27/09 06:58 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
My buddies open bow Chapparal had a GM305 stern drive, regular clockwise rotation.
Re: 340 in a boat [Re: repad] #420584
07/27/09 07:30 PM
07/27/09 07:30 PM
Thanks,
Can you string some jumper cables in and just crank it? If it's inboard, direct drive, is there a prop on it? (You can wrench the engine over and make sure the prop turns the same way, then figure rotation from prop pitch)
Re: 340 in a boat #420585
07/27/09 07:44 PM
07/27/09 07:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The 340 boats that we sold that were made by Chrysler Boats had regular clockwise rotation. Make sure of what you have before jumping to conclusions. The boaats I am referring to were produced in the mid 70's.
Re: 340 in a boat [Re: MoparforLife] #420586
07/27/09 08:17 PM
07/27/09 08:17 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
is the boat savable? i would buy it and restore it sure an unusual one dan
Re: 340 in a boat [Re: ph23vo] #420587
07/27/09 09:47 PM
07/27/09 09:47 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
As I said ..stern drive boats are standard rotation
