68 'cuda grille/bezels restoration #420563
07/27/09 03:12 PM
07/27/09 03:12 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Where is the best place to purchase a restored set of grilles/bezels for a '68 cuda? Or to get my originals restored?
At Carlisle I got a card from "Gino's Mopars" who apparently restores 67-69 cuda parts. Has anyone used him before? His stuff looked nice. I talked to him about mouldings and he seemed expensive.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 68 'cuda grille/bezels restoration [Re: Erik] #420564
07/27/09 10:04 PM
07/27/09 10:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Restore what you have. Its aluminum trim restoration. The usual suspects are Alltrim and MrBelvedere here on Moparts that do great work.
You probably need front grille surrounds, headlight bezels, rear trunk trims, and wheel aluminum mouldings? Thats the usual 67/68 Barracuda combo meal #1.
The plastic grilles you can repaint yourself. Stainless you could do yourself or maybe find someone local. On those cars the stainless is rarely dented. IMHO, having the two guys listed above just polish un-smashed stainless is a waste of talent.
Re: 68 'cuda grille/bezels restoration [Re: Erik] #420565
07/27/09 11:52 PM
07/27/09 11:52 PM
capac michigan
MCB Restorations Offline
capac michigan
We restore 68 and 69 Cuda grill / headlight surrounds on a regular basis. See attached examples of ones we have completed.
Matt @ MCB Mopar Metal Restoration www.tuffwheelrestoration.com PH 810-395-7162
Stainless Steel and Aluminum trim restoration by MCB Restorations. We offer show quality trim restoration for all brands but specialize in Mopar. See our website for other examples www.mcbrestorations.com or give us a call at (810) 395-7162
Re: 68 'cuda grille/bezels restoration [Re: MCB Restorations] #420566
07/28/09 09:00 AM
07/28/09 09:00 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Matt - You have a PM!
Re: 68 'cuda grille/bezels restoration [Re: Erik] #420567
07/28/09 12:31 PM
07/28/09 12:31 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Do it yourself...
A LOT of work, and I am sure a pro could do better, but I am very happy with the results...
Can't find the thread where I showed it...
Re: 68 'cuda grille/bezels restoration [Re: Erik] #420568
07/28/09 12:57 PM
07/28/09 12:57 PM
OR
AllTrim Plus Offline
OR
make sure to ask if its anodized...
Re: 68 'cuda grille/bezels restoration [Re: 6T6Cuda] #420569
07/28/09 01:13 PM
07/28/09 01:13 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do it yourself...
If it's real straight and not dented up and you are working with a budget yes do it yourself. Try one smaller piece to see if you want/can do more. Having someone do all the aluminum in car like that is $$$. I'd think well well over $1000 for grilles, headlight bezels, trunk trims, wheel moldings... Probably double and plus. There's really a lot of work into restoring those.
But fixing dents, smashes, tweeks in aluminum is very hard to get to look decent. The grille and bezel surrounds on those are common to be smashed flat. And the aluminum's got a lip that's tough to work around (for a non professional). Same for trunk trim.
Re: 68 'cuda grille/bezels restoration [Re: autoxcuda] #420570
07/28/09 01:22 PM
07/28/09 01:22 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I just need the grilles/bezels done. I have all of the other mouldings in great shape.
Re: 68 'cuda grille/bezels restoration [Re: AllTrim Plus] #420571
07/28/09 03:39 PM
07/28/09 03:39 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
While not as nice or correct, I clear coated mine with PPG 2021, they are more glossy, and are not a "protected" but should work for now...
