Re: Warning, for welders and folks using 'common' garage...
[Re: blue_stocker]
#420201
07/27/09 11:01 AM
07/27/09 11:01 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
wow, thanks for the heads up
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#420202
07/27/09 11:18 AM
07/27/09 11:18 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
I learned about most, if not all of these fatal gas combos in college, then in the field. I welded in a steel mill as a maintenance guy. Whenever I would tig up an oxygen line I had to flush the lines out with tryclorathane, a nasty chemical that leaches into your skin, and if enough is let into your system it can mess up your DNA, and screw with any chances on having kids, so on and so on... Welding and chemicals are nasty. I havent read up totally on tryclorathane, but a guy I welded with got a bunch dumped on him when he was younger, and Im not certain, but because of this chemical his only kid has ceral paulsey, or something like that.
Always be carefull, and thanks for the heads up on this thread.
KAsey
[Re: Moparnut426]
#420203
07/27/09 12:19 PM
07/27/09 12:19 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
It's stuff like this that makes me look back at a few things that I have done and makes me wonder why I'm still alive.
A good friend on mine, her dad died of a strange form of cancer that is hardly ever seen. It turns out it was brought on from him working with fiberglass. He worked on his boat from time to time in his garage and he used this industrial fiberglass reisin that was bought over the counter......very sad.
Now I have a wife and a five year old that I have to answer too.......
Thanks for the wake up call.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: challenger73400]
#420205
07/27/09 07:25 PM
07/27/09 07:25 PM
Posts: 16,928 NC
440Jim
NC
I will NEVER use brake fliud to clean my surface.
Don't you mean brake cleaner?
[Re: blue_stocker]
#420208
07/27/09 10:18 PM
07/27/09 10:18 PM
Posts: 22,697 Bitopia
jcc
Bitopia
As scary as that article is, I think it should be noted it was written by a Welder, who I don't think has any PhD. Also I believe the Phosgene reaction mentioned requires a strong source of UV, which just welding in proximity to the right chemicals is part of the problem. Funny how this gets everybody excited, but asbestos in undercoatings, brakes, clutches, bezene in fuel, cadium in plating, lead in used engine oil and battery terminals, high UV levels on bare hands when welding, etc. hardly registers a blip.
[Re: jamesc]
#420210
07/28/09 01:56 AM
07/28/09 01:56 AM
Posts: 793 Utah
topbrent
Utah
Thank you for posting this. I did some welding over the weekend...and cleaned the area to be welded with brake cleaner... Luckily several hours passed between the application and the welding...and it was outdoors. I am more than a little alarmed at the moment. Good wakeup call
[Re: 440Jim]
#420211
07/28/09 05:17 AM
07/28/09 05:17 AM
Posts: 303 southwest Alabama
challenger73400
southwest Alabama
Oops! I must be getting old.
[Re: jamesc]
#420213
07/28/09 10:43 PM
07/28/09 10:43 PM
jcc
Bitopia
Ah, I did my research, pretty much says "UV" when welding is the agent for the phosgene, and my current source to back up my "belief" is: http://www.reference.com/browse/wiki/Phosgene
[Re: jcc]
#420214
07/29/09 01:22 AM
07/29/09 01:22 AM
Thanks for the post and I think regardless of one fact or another it is safe to say when using anything containing chemicals for Christ sakes be careful.
[Re: jcc]
#420216
07/29/09 06:59 PM
07/29/09 06:59 PM
Posts: 5,875 communist bloc of new jersey
jamesc
after looking this stuff up i expect the men in black to be pulling up any minute now. bottom line is you expose chloronated hydrocarbons to heat/UV and you make phosgene, you expose chloroform to UV in the presence of oxygen you make phosgene...in other words if you clean metal with brake clean (TCE type) and weld on it before it's completely evaporated you make phosgene (not to mention HCL)...if you think this is incorrect give it a try. line 5 fire fighting methods http://www.jtbaker.com/msds/englishhtml/T4940.htm Quote:
When chlorohydrocarbon vapors are thermally cracked in open flames or arcs associated with furnaces, boilers, or welding apparatus, sufficient phosgene may be generated to create a hazard.
Phosgene is released during the welding of metals that have been cleaned up with chlorinated solvents, so welders may be exposed to this compound.
