Page 3 of 7 1 2 3 4 5 6 7
Re: Dodge Truck Registry 1972-1980 [Re: orioncrw] #4177
05/22/05 01:50 AM
05/22/05 01:50 AM
just like to add my truck the vin is w24bf8s218347 its a 1978 w200, 360 2bbl,np435 4spd,203t case, dana 60 front and rear with 4.88 gears,regular cab long box custom.I think it may have been green or tan originaly with green interior when i bought it it was white with blue interior
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4178
07/04/05 10:04 AM
07/04/05 10:04 AM
Milwaukee, Wisconsin
Forgiven Offline
Forgiven  Offline
1976 Dodge Warlock 440 4x4, W13BD65334004, sunburst orange, black interior, 727, dana 44 front, chrysler corp rear, 3.23's
Equipment label:
GH3, CP1, DS5, FA3, HE4, HGA, YA4, LM4, GK9601, RA4, SJ6, SW1, TK9 F, WP2 F, WX1, YA3, ED6, AV1, DF5, KN2, HA6, HF2, HU9, KT1, SL3, MC1, SF1, ST1, SW4, TK9 R, WP2 R, XA1, YF1, NF900
He's the same yesterday, today, and forever! 70 Charger R/T
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4179
07/23/05 04:28 PM
07/23/05 04:28 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Online shocked
dynotune440  Online Shocked
ok, here is another one.....
1977 Ramcharger SE Metalic Black.
440, auto, cruise, dealer a/c, 100 amp alt, high back buckets in parchment, volt/vac, clock, trans cooler, tire carrier, roll bar, am radio, lower wide moulding and tailgate mouldings only, small mirrors, standard rear bumper and front bumper guards, and original general scrambler tire on white wagon wheel on carrier. will get VIN info later. Last registered in CA in 1990. Runs GREAT!!
Was a "LOOKER" in it's day!!!
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: Dodge Truck Registry 1972-1980 [Re: dynotune440] #4180
07/26/05 12:34 AM
07/26/05 12:34 AM
and a pic after a little cleaning.......
Was a "LOOKER" in it's day!!! o
pcorn:
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4181
08/08/05 03:03 PM
08/08/05 03:03 PM
I'm new to the forum.
I have a 78 Dodge Custom 150.
318
Automatic
Bright Canyon Red (in/out)
103,000 miles
VIN ?
Rear Axle size ?
Gear Ratio ?
Appears to have no options.
Not sure about the other info. If I can find any more I will update.
Re: Dodge Truck Registry 1972-1980 #4182
08/09/05 12:35 AM
08/09/05 12:35 AM
Souderton Pa
Ramchargerkid77 Offline
Souderton Pa
here you go
A10BJ7128623.
TrailDuster sport
Bronze with white top
Tan gut
(9.25 3.91s sure grip
Manual Stearing
Going to take a ride in my Trailduster be back in 8.9sec
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4183
08/14/05 10:27 PM
08/14/05 10:27 PM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Here is the list of what I have and some of the info on each, I will have to edit this later.
73CCLWB D27BJ3S040523 b.d. 1072 400 727 Bronze/white
74CCSWB W17AF4S041605 b.d.1073 mdh 102001 360 727 div. 205 8 3/4/D44 no A/C, color ? I've heard of a "butterscotch" special color/white
74CCSWB D17AF4S095086 Tan/White A/C b.d. 0374 mdh 030419L T.O.N. L6625110 no drive train bought for non rust A/C cab for my 4x4
75LWB D14DE5S040062 now 360 727 A/C Blue/white (for sale)
75LWB D24BF5S169677 360 727 Yellow/White T-Boned drivers side parts truck
77SWB D14AE7S158855 T.O.N. HW861001 Bronze no drive train parts trk.
77CCLWB D27BF7S129245 b.d. 0377 mdh 0302002 T.O.N. HS168501 360 435 Silver
77LWB D14BJ7S216835 b.d. 0677 mdh 061400L T.O.N. HS212201 400 727
I also have a 96CCLWB V10 AOD, 6 84-85 trks, 2 Rampages, and a 55 If I edit this posting I will add a * in front of any I add more info on. PM or shinnery@taylortel.net if you have questions Bryce
Re: Dodge Truck Registry 1972-1980 [Re: shinnery] #4184
09/06/05 05:25 PM
09/06/05 05:25 PM
looking for more information on dodge palomino's that were built in 1979. I have some info on these trucks, and have information on about 30+ of these trucks, and on 6 of them a lot of information.
Re: Dodge Truck Registry 1972-1980 [Re: dynotune440] #4185
09/24/05 10:36 PM
09/24/05 10:36 PM
here's another one for you.....
1979 W150 swb
360 4bbl, NP435 4SPD
factory a/c, adventurer se package, 3 pt mirrors, and factory sunroof.
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4186
09/30/05 08:57 PM
09/30/05 08:57 PM
Franklin CT
syleng1 Offline
syleng1  Offline
Franklin CT
1972 Dodge W-200 PW
8ft bed std cab
378 CI Detroit Military Diesel, dual 105 amp alternators.
Allison 4 speed Auto
NP-208 Transfercase
Dana 60 Front axle 4.56ratio, 13" disks/rotors
Corp 14 bolt Rear, 4.56 ratio Detroit locker 13"x4" drums
Air ride 2500lbs air bags (rear)
Western Cadet Steel diamond plate flatbed
6-7 ton Rugby dump hoist (electric/hydraulic)
28ton dump hinge (alittle over kill.... but)
Cab was removed off body and factory floors welded in. Entire cab including white on roof top was sandblasted to bare metal and Rhino linned inside and out 360degrees. I replaced the dash frame with a 79 dash frame with a/c vents. But I reinstalled my factory dash pad and gauges. Factory am radio and metal interior door pannels.
Factory gas tank behind the front seat. (Qualitex Ranch model in blue)
This truck is outfitted with a 8ft Meyers front plow and wired for its Buyers 2-3 yard Stainless steel sander.
Class of 1972 in B-5 blue
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4187
10/30/05 01:19 PM
10/30/05 01:19 PM
Tracy, New Brunswick, Canada
magnumcharger Offline
Hi, I had a really neat truck several years ago. It was an Adventurer SE regular cab, longbox, with the following options: 440/auto, air, tach, dual tanks, lots of chrome, and trailer towing package. It was red with a red interior.
It was rusting pretty badly, so I basically swapped everything above the frame and ended up rebodying it to a club-cab shortbox, putting all of the stock options back in and changing the colour to Alpine white.
I ended up keeping the build tag, and this is how it reads:
Top - 33164 D15 131 CONV CABS74
Middle - PY1417 PZ3441 PXT
Bottom - C1 4B08S138201 AC030501
Maybe you might be able to tell me what I had from this.
Re: Dodge Truck Registry 1972-1980 [Re: magnumcharger] #4188
10/30/05 07:42 PM
10/30/05 07:42 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Here are some more of my 2wds:
D13ANAS128***, built 02/80. Root Beer brown on Tan, Short Stepside. Originally S6/4-spd OD, not really many options except PS and Brakes. Even a Radio Delete truck. Custom trim level. Now sports a 440/auto
D14ABAS014*** Early build, 09/73. Green with black interior, NO options, Originally a Slant Six/3 on the Tree SWB. Now has a 318/auto
D14AF3S022*** Another early build, 09/72. Cab only at this point, originally a brown/white Adventurer SE Reg. Cab LWB. 360/auto, not real sure on what options it had only it was an SE.
D14JE9S221*** 04/79. This one is also a cab only. Started life as a '79 Palomino. I remember the Truck in the JY before I bought the cab. Actually, I bought most of it except frame, engine, and bed (bed was gone already as was the rt fender). Started as anb Adventurer, tan/white on Tan. Tilt column, not real sure what radio. It also HAD a buildsheet that I saw and option sticker but by the time I got back for the cab they were GONE. Had air/PS/PB also and a light package.
D17AF3S206*** Built 07/73. Club Cab parts Truck. Originally an Adventurer. Not a stright panel on it, this one is for parts!
D14BB7S224*** 08/77 build. Was a Blue '77 Adventurer, low options (manual brakes and no air, though it has an AM/FM radio), started out as a S6/auto truck, rubber mats even.
D14AN9S 135*** Built 10/78. Brown on Tan '79, low options (manual brakes, no air, but PS), Slant Six/4-spd granny LWB.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4189
11/24/05 02:11 AM
11/24/05 02:11 AM
Franklin County VA
DRTMopar Offline
super street
DRTMopar  Offline
super street
Franklin County VA
1979 Dodge Adventurer 100
2wd 318 4speed
Ext. Black
Int. Red
Stepside
in the end 440+4, 8 3/4 suregrip, air ride, 4- link, buddy seat, 17x11-r 16x8-f tq thrust II's. man i can't wait to be done
Re: Dodge Truck Registry 1972-1980 [Re: DRTMopar] #4190
01/02/06 10:47 PM
01/02/06 10:47 PM
ME
79machocharger Offline
ME
Hey machoman,
1978 macho ramcharger
A10BF8S1176?S
Brite tan met
tan enterior
automatic transmission
I'll just list off the codes
AV2
DE5
EC4
HE2
JM1
WHLS 15X8 PTD ROAD
1650 REAR SPRING
TK9F
ONE SPARE TIRE S/A REAR
YW4 GVW
EC4 360 ENG 4037449
FA3 TRANS A 4039542
DECALS MACHO PROGRAM
CP1
DS5
FA3
HF5
KT5
LP6
SF1
ST1
TK9R
WP2R
Y81
NF5011
0W0639
OY0456
PY6486
the truck still has the radiator support tag.
56879 AW1 106
PY6486
A10BF8S117605 JC032601
Ryan
RIP 1977 W150 440 "D" code [Re: MachoMan] #4191
01/05/06 10:46 PM
01/05/06 10:46 PM
found in a Wrecking Yard in Bakersfield, CA.....
W14BD7S075561
Paint code PY4009
metalic black short bed adventurer package that had seen better days. was a nice truck in it's hay day, but now a PILE!!
RIP 1978 Ramcharger SE 440 [Re: MachoMan] #4192
01/05/06 10:49 PM
01/05/06 10:49 PM
Found a 78 440 Ramcharger SE in a JY today in Santa Paula CA. this RC had all of the VIN's off of it, but appeared to be stock factory. Was a loaded truck, I determined that it was a 78 by the fact of the tilt coloum and the amber lenes. Was canyon red sunfire metalic above and below mouldings, and canyon red in the center. loaded truck, but gone now. My guess is that it didn't pass emissions testing out here, body was CHERRY!!!
recent buy, 78 W150 swb Macho pkg [Re: dynotune440] #4193
02/21/06 10:56 AM
02/21/06 10:56 AM
78 W150 swb MACHO pkg. 360 2bbl, 4speed, 3 pt mirrors, tach, volt/vac, radio delete, heater only, 3.55 gears, bucket seats. Really rough truck, but has potential. canyon red sunfire metalic/black macho package, but missing roll bar.
Re: Dodge Truck Registry 1972-1980 [Re: MachoMan] #4194
03/02/06 08:02 PM
03/02/06 08:02 PM
I HAVE 1979 LIL RED EXPRESS.A 2YR FRAME OFF RESTORATION.BOUGHT HARD TO FIND PARTS FROM DODGE CONNECTION.(THANK'S DANNY).IT HAS BLACK INTERIOR.BUCKET SEAT PKG.NEW CARPET,REBUILT REAR AXLE.NEW POSI 351 GEARS.FOUND A NOS AM/FM CB RADIO.TACH,AMP & VOLT PKG.FACTORY SLOTED WHEELS. & LUCKY TO FIND NOS FRONT FENDERS.FUN TO DRIVE & RUNS STRONG.
Re: Dodge Truck Registry 1972-1980 [Re: cdwmotorsports] #4195
03/11/06 04:35 PM
03/11/06 04:35 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I have a 1978 Big Block Crewcab Shortbed 3/4 ton pickup and a 74 D100 318/727 Long bed 8 3/4 truck I will get info this weekend. Both are for sale if anyone is looking....
Well I know it has been awhile but I figured I would update you guys on my trucks. The 74 is all but gone. The 78 Crewcab that was a 440 shortbed truck is getting the body taken off and sat on a 93 Cummins d350 chassis.
I will give you as much info as I can on the 440 truck and get the rest tomorrow.
VIN number
outside color Green
interior color Green
transmission 727
front axle D60
gear ratio
any extra cost options(Adv SE, tach, tuff wheel, paint procedure, wheels etc...)
If the truck still has the underhood equiptment label, i would like those codes.
If the truck still has the radiator support tag (commonly known to car guys as fender tag) the info off those
eBay-cdwmotorsports
Re: Dodge Truck Registry 1972-1980 [Re: cdwmotorsports] #4196
03/16/06 11:12 PM
03/16/06 11:12 PM
another PALOMINO was rescued!
2wd lwb prospector packageI 360 4bbl VIN "T" automatic, no a/c pretty basic truck, except that it has the big factory trailer tow mirrors(not the 3pt mirrors) like the one's that come on the 1 ton trucks, and had a factory transmission cooler on it, but no tow package what so ever. came out of the central ca area. 74,000 clicks on the odo, but has a rod knocking.....bummer
