Re: Dodge Truck Registry 1972-1980
[Re: orioncrw]
#4177
05/22/05 01:50 AM
05/22/05 01:50 AM
just like to add my truck the vin is w24bf8s218347 its a 1978 w200, 360 2bbl,np435 4spd,203t case, dana 60 front and rear with 4.88 gears,regular cab long box custom.I think it may have been green or tan originaly with green interior when i bought it it was white with blue interior
[Re: MachoMan]
#4178
07/04/05 10:04 AM
07/04/05 10:04 AM
Posts: 104 Milwaukee, Wisconsin
Forgiven
1976 Dodge Warlock 440 4x4, W13BD65334004, sunburst orange, black interior, 727, dana 44 front, chrysler corp rear, 3.23's Equipment label: GH3, CP1, DS5, FA3, HE4, HGA, YA4, LM4, GK9601, RA4, SJ6, SW1, TK9 F, WP2 F, WX1, YA3, ED6, AV1, DF5, KN2, HA6, HF2, HU9, KT1, SL3, MC1, SF1, ST1, SW4, TK9 R, WP2 R, XA1, YF1, NF900
He's the same yesterday, today, and forever!
70 Charger R/T
[Re: MachoMan]
#4179
07/23/05 04:28 PM
07/23/05 04:28 PM
Posts: 5,301 CA, Proprietor; The "PALOMINO"...
dynotune440
ok, here is another one..... 1977 Ramcharger SE Metalic Black. 440, auto, cruise, dealer a/c, 100 amp alt, high back buckets in parchment, volt/vac, clock, trans cooler, tire carrier, roll bar, am radio, lower wide moulding and tailgate mouldings only, small mirrors, standard rear bumper and front bumper guards, and original general scrambler tire on white wagon wheel on carrier. will get VIN info later. Last registered in CA in 1990. Runs GREAT!! Was a "LOOKER" in it's day!!!
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
[Re: dynotune440]
#4180
07/26/05 12:34 AM
07/26/05 12:34 AM
dynotune440
and a pic after a little cleaning....... Quote:
ok, here is another one..... 1977 Ramcharger SE Metalic Black. 440, auto, cruise, dealer a/c, 100 amp alt, high back buckets in parchment, volt/vac, clock, trans cooler, tire carrier, roll bar, am radio, lower wide moulding and tailgate mouldings only, small mirrors, standard rear bumper and front bumper guards, and original general scrambler tire on white wagon wheel on carrier. will get VIN info later. Last registered in CA in 1990. Runs GREAT!! Was a "LOOKER" in it's day!!! o pcorn:
[Re: MachoMan]
#4181
08/08/05 03:03 PM
08/08/05 03:03 PM
I'm new to the forum.
I have a 78 Dodge Custom 150.
318 Automatic Bright Canyon Red (in/out) 103,000 miles VIN ? Rear Axle size ? Gear Ratio ?
Appears to have no options. Not sure about the other info. If I can find any more I will update.
#4182
08/09/05 12:35 AM
08/09/05 12:35 AM
Posts: 33 Souderton Pa
Ramchargerkid77
Souderton Pa
here you go A10BJ7128623. TrailDuster sport Bronze with white top Tan gut (9.25 3.91s sure grip Manual Stearing
Going to take a ride in my Trailduster be back in 8.9sec
[Re: MachoMan]
#4183
08/14/05 10:27 PM
08/14/05 10:27 PM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
Here is the list of what I have and some of the info on each, I will have to edit this later. 73CCLWB D27BJ3S040523 b.d. 1072 400 727 Bronze/white 74CCSWB W17AF4S041605 b.d.1073 mdh 102001 360 727 div. 205 8 3/4/D44 no A/C, color ? I've heard of a "butterscotch" special color/white 74CCSWB D17AF4S095086 Tan/White A/C b.d. 0374 mdh 030419L T.O.N. L6625110 no drive train bought for non rust A/C cab for my 4x4 75LWB D14DE5S040062 now 360 727 A/C Blue/white (for sale) 75LWB D24BF5S169677 360 727 Yellow/White T-Boned drivers side parts truck 77SWB D14AE7S158855 T.O.N. HW861001 Bronze no drive train parts trk. 77CCLWB D27BF7S129245 b.d. 0377 mdh 0302002 T.O.N. HS168501 360 435 Silver 77LWB D14BJ7S216835 b.d. 0677 mdh 061400L T.O.N. HS212201 400 727 I also have a 96CCLWB V10 AOD, 6 84-85 trks, 2 Rampages, and a 55 If I edit this posting I will add a * in front of any I add more info on. PM or shinnery@taylortel.net if you have questions Bryce
[Re: shinnery]
#4184
09/06/05 05:25 PM
09/06/05 05:25 PM
dynotune440
looking for more information on dodge palomino's that were built in 1979. I have some info on these trucks, and have information on about 30+ of these trucks, and on 6 of them a lot of information.
[Re: dynotune440]
#4185
09/24/05 10:36 PM
09/24/05 10:36 PM
dynotune440
here's another one for you..... 1979 W150 swb 360 4bbl, NP435 4SPD factory a/c, adventurer se package, 3 pt mirrors, and factory sunroof.
[Re: MachoMan]
#4186
09/30/05 08:57 PM
09/30/05 08:57 PM
Posts: 765 Franklin CT
syleng1
Franklin CT
1972 Dodge W-200 PW 8ft bed std cab 378 CI Detroit Military Diesel, dual 105 amp alternators. Allison 4 speed Auto NP-208 Transfercase Dana 60 Front axle 4.56ratio, 13" disks/rotors Corp 14 bolt Rear, 4.56 ratio Detroit locker 13"x4" drums Air ride 2500lbs air bags (rear) Western Cadet Steel diamond plate flatbed 6-7 ton Rugby dump hoist (electric/hydraulic) 28ton dump hinge (alittle over kill.... but) Cab was removed off body and factory floors welded in. Entire cab including white on roof top was sandblasted to bare metal and Rhino linned inside and out 360degrees. I replaced the dash frame with a 79 dash frame with a/c vents. But I reinstalled my factory dash pad and gauges. Factory am radio and metal interior door pannels. Factory gas tank behind the front seat. (Qualitex Ranch model in blue) This truck is outfitted with a 8ft Meyers front plow and wired for its Buyers 2-3 yard Stainless steel sander. Class of 1972 in B-5 blue
[Re: MachoMan]
#4187
10/30/05 01:19 PM
10/30/05 01:19 PM
Posts: 2,489 Tracy, New Brunswick, Canada
magnumcharger
Hi, I had a really neat truck several years ago. It was an Adventurer SE regular cab, longbox, with the following options: 440/auto, air, tach, dual tanks, lots of chrome, and trailer towing package. It was red with a red interior. It was rusting pretty badly, so I basically swapped everything above the frame and ended up rebodying it to a club-cab shortbox, putting all of the stock options back in and changing the colour to Alpine white. I ended up keeping the build tag, and this is how it reads: Top - 33164 D15 131 CONV CABS74 Middle - PY1417 PZ3441 PXT Bottom - C1 4B08S138201 AC030501
Maybe you might be able to tell me what I had from this. Thanks
[Re: magnumcharger]
#4188
10/30/05 07:42 PM
10/30/05 07:42 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
Here are some more of my 2wds:
D13ANAS128***, built 02/80. Root Beer brown on Tan, Short Stepside. Originally S6/4-spd OD, not really many options except PS and Brakes. Even a Radio Delete truck. Custom trim level. Now sports a 440/auto
D14ABAS014*** Early build, 09/73. Green with black interior, NO options, Originally a Slant Six/3 on the Tree SWB. Now has a 318/auto
D14AF3S022*** Another early build, 09/72. Cab only at this point, originally a brown/white Adventurer SE Reg. Cab LWB. 360/auto, not real sure on what options it had only it was an SE.
D14JE9S221*** 04/79. This one is also a cab only. Started life as a '79 Palomino. I remember the Truck in the JY before I bought the cab. Actually, I bought most of it except frame, engine, and bed (bed was gone already as was the rt fender). Started as anb Adventurer, tan/white on Tan. Tilt column, not real sure what radio. It also HAD a buildsheet that I saw and option sticker but by the time I got back for the cab they were GONE. Had air/PS/PB also and a light package.
D17AF3S206*** Built 07/73. Club Cab parts Truck. Originally an Adventurer. Not a stright panel on it, this one is for parts!
D14BB7S224*** 08/77 build. Was a Blue '77 Adventurer, low options (manual brakes and no air, though it has an AM/FM radio), started out as a S6/auto truck, rubber mats even.
D14AN9S 135*** Built 10/78. Brown on Tan '79, low options (manual brakes, no air, but PS), Slant Six/4-spd granny LWB.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: MachoMan]
#4189
11/24/05 02:11 AM
11/24/05 02:11 AM
Posts: 309 Franklin County VA
DRTMopar
super street
super street
Franklin County VA
1979 Dodge Adventurer 100 2wd 318 4speed Ext. Black Int. Red Stepside in the end 440+4, 8 3/4 suregrip, air ride, 4- link, buddy seat, 17x11-r 16x8-f tq thrust II's. man i can't wait to be done
RIP 1977 W150 440 "D" code
[Re: MachoMan]
#4191
01/05/06 10:46 PM
01/05/06 10:46 PM
dynotune440
found in a Wrecking Yard in Bakersfield, CA..... W14BD7S075561 Paint code PY4009 metalic black short bed adventurer package that had seen better days. was a nice truck in it's hay day, but now a PILE!!
RIP 1978 Ramcharger SE 440
[Re: MachoMan]
#4192
01/05/06 10:49 PM
01/05/06 10:49 PM
dynotune440
Found a 78 440 Ramcharger SE in a JY today in Santa Paula CA. this RC had all of the VIN's off of it, but appeared to be stock factory. Was a loaded truck, I determined that it was a 78 by the fact of the tilt coloum and the amber lenes. Was canyon red sunfire metalic above and below mouldings, and canyon red in the center. loaded truck, but gone now. My guess is that it didn't pass emissions testing out here, body was CHERRY!!!
recent buy, 78 W150 swb Macho pkg
[Re: dynotune440]
#4193
02/21/06 10:56 AM
02/21/06 10:56 AM
dynotune440
78 W150 swb MACHO pkg. 360 2bbl, 4speed, 3 pt mirrors, tach, volt/vac, radio delete, heater only, 3.55 gears, bucket seats. Really rough truck, but has potential. canyon red sunfire metalic/black macho package, but missing roll bar.
[Re: MachoMan]
#4194
03/02/06 08:02 PM
03/02/06 08:02 PM
I HAVE 1979 LIL RED EXPRESS.A 2YR FRAME OFF RESTORATION.BOUGHT HARD TO FIND PARTS FROM DODGE CONNECTION.(THANK'S DANNY).IT HAS BLACK INTERIOR.BUCKET SEAT PKG.NEW CARPET,REBUILT REAR AXLE.NEW POSI 351 GEARS.FOUND A NOS AM/FM CB RADIO.TACH,AMP & VOLT PKG.FACTORY SLOTED WHEELS. & LUCKY TO FIND NOS FRONT FENDERS.FUN TO DRIVE & RUNS STRONG.
[Re: cdwmotorsports]
#4196
03/16/06 11:12 PM
03/16/06 11:12 PM
dynotune440
another PALOMINO was rescued! 2wd lwb prospector packageI 360 4bbl VIN "T" automatic, no a/c pretty basic truck, except that it has the big factory trailer tow mirrors(not the 3pt mirrors) like the one's that come on the 1 ton trucks, and had a factory transmission cooler on it, but no tow package what so ever. came out of the central ca area. 74,000 clicks on the odo, but has a rod knocking.....bummer
