Race 727/904 build up
#4070
10/04/03 09:20 PM
10/04/03 09:20 PM
Engine combos have been discussed, as have suspension. I figured it was time to pick the brain of a few of our transmission gurus. So guys, how would you build a 727 or 904 for race use? Break it down into et/mph levels, if needed.
Re: Race 727/904 build up
#4071
10/04/03 10:44 PM
10/04/03 10:44 PM
Posts: 16,929 NC
440Jim
NC
I am not a trans guru, but I have built my own for a 600 hp application. And I have torn them down after a years running and inspected things to see how they held up (twice). Also, I have done a few for friends making less power. So, my 2-cents to get things started:
1) Get a good valve body
2) Get a good valve body
3) Use a 727, they are strong as an ox
- a heavy duty front band servo strut is available from a few vendors, Superior #K031 for example.
- Sonnex makes a billet rear servo piston that doesn't crack, and resists getting cocked in the bore. #22912
- for low band apply valve bodies, I think a stronger rear servo retainer is a good idea, and shim inside the small piston spring close to solid, so the cushion spring doesn't compress.
- use the '70 and earlier front servo (not the '71 oil cushioned)
- Set the clutch pack clearances on the tight end of tolerances, especially the rear clutch
- Get some new bushings put in almost everywhere if it hasn't been done in 30 years.
- The front pump bushing (for the converter) is a mandatory replacement everytime, use the babbit ones
- A deep sump pan and filter extension is a good idea and makes the fluid level less critical
- New springs and rollers in the sprag ($2), or a new bolt-in one
See my trans page on my website for some other options:
440 Jim's web site - 727 Trans Tips
#4072
10/04/03 10:59 PM
10/04/03 10:59 PM
Posts: 16,929 NC
440Jim
NC
I found something I saved that I posted before: If you are going to a trans brake, the trans must be modified for its use during the build, so now is the time to put it in. For example, drilled oil pressure relief holes in the clutch, drilled case for the solinoid wire, relocated vent, number of front clutch springs, etc. I don't have any cook book list to give, but here is my 2-cents. A 727 can do 600 hp with very little changes. But some things are nice to have for additional piece of mind or to assure a good part. - A good valve body (with a brake in your application) - Check everything for wear (pump rotors, drums, ring rubbing surfaces, etc.) - Relocate the vent with a brake (plug the front vent) - All new bushings (just do it now, any refresh maybe not) - All new thrust washers (cheap insurance) - Set clutch pack clearances for the application ex/ 0.012"-0.015" per front disc (0.060" for 5 discs) ex/ 0.025"-0.035" rear with 4 discs - Check sprag for wear, at a minimum new rollers and springs - Bolt in sprag optional, but now is the time to do it - 3.8 or 4.2 front band servo lever (see valve body instructions) - Rigid/solid front band (IMO releases better than flex band) - Babbit converter bushing in the trans pump housing - Pre-'71 "solid" front servo, or shim the newer oil cushioned servo so it is solid - Shim the rear servo so the cushion spring is almost solid There are other "optional" mods on my web site: http://pages.moparpages.com/440Jim/website/id4trans.html I like the oil passage enlargement mods (ported reaction shaft support between the rings, clutch retainer holes 5/32", 1/16" oil hole to the sprag).
[Re: 440Jim]
#4073
10/05/03 11:02 AM
10/05/03 11:02 AM
anyone else have anything to add?
#4074
10/05/03 04:54 PM
10/05/03 04:54 PM
#4075
10/05/03 05:00 PM
10/05/03 05:00 PM
It's not "perk", I felt it would benefit ALL members to have this info and be able to add it to the archives.
[Re: 440Jim]
#4076
10/05/03 06:33 PM
10/05/03 06:33 PM
I've been doing some heavy research on street/strip racing 727 trans. 440Jim was kind enough to provide alot of information for me, thanks again Jim! I'm am trying to gather enough information for my third trans... this one will be done correctly...lol, no more BOOM for me anyway, I have a better understanding of the internal parts that should be used, but I'm still unsure of what types of SFI approved cases there are for the 727. I have found a case that is call an "UltraBell" and was wondering if anyone knows of this case and if it's any good. Are there any other SFI approved cases? Are there any clearance issues to be concerned with...ie; A-body application? If the UltraBell case is a good/safe case then my last question would be concerning the starter location on the case. It appears to me in the pic that the starter mounts from the side rather than from the front....uummm clearance issue problem maybe? Here is a picture of the case with a discription. The Ultra-Bell and Ultra-Case combination provides tremendous strength and versatility by allowing the case to bolt to the following designs: Buick, Chevrolet, Chrysler, Ford, Oldsmobile and Pontiac engines. The combination eliminates the need for a flexplate shield and transmission shield. Furthermore, the Ford and Chrysler engines allow the starter to bolt directly to the "Ultra-Bell". Performance benefits include: Adjustable transmission brake release. Improved CNC machined oil passages which increase the oil flow of the transmission brake. Eliminates case breakage through increased aluminum in critical weak areas of the stock powerglide cases. Less flex on the shift leaver due to increase of case material and less seal leakage. The modulator boss has been increased drastically to eliminate cracking. The "Ultracase" is approximately four pounds heavier than a stock powerglide case.
[Re: CokeBottleKid]
#4078
10/05/03 06:51 PM
10/05/03 06:51 PM
Hey CBK That's why I'm asking partner, I don't know...lol I would think that there is an SFI approved case for the 727 so I don't have to run a trans blanket or a shield. If someone tells me that "NO" there are not any approved SFI cases for the 727, then I will start looking for information on another type of trans for my 440 that is SFI approved and does not need a trans blanket or sheild.
Post deleted by Defbob
[Re: CokeBottleKid]
#4080
10/05/03 07:30 PM
10/05/03 07:30 PM
#4085
10/05/03 10:09 PM
10/05/03 10:09 PM
Posts: 473 PA
joez
PA
I'll post what i can remember off hand. This has worked so far to get my 3025 lb car to go 5.60s at 124 in the 1/8. Which should be a 8.70-8.80 at 156+ in the 1/4. The trans is a very lo buck deal too. -5 alto red grooved front clutches(pressure plate cut down to fit the extra friction) -4 alto red solid rear clutches(used early bellville spring with the 1/2 circle cutouts and correct pressure plate) -solid snap rings on both drums(front snap ring is a th-350 part for the direct drum) -kolene steels throughout -bands that came with the b&m kit -3.8:1 lever -reinforced front band apply strut -trans king brake -teflon seal rings throughout(must use these when using a high pressure valve body, the stock rings wear out very quick. Use chrome moly rings if you have an aluminum drum that the rings ride on) -new rollers and springs in stock sprag -tci aluminum deep pan Attention to detail and frequent inspection keeps this together without problems for about 50 passes this year. Proper burnout procedures also, start in 2nd and shift to 3rd before stopping. I can't remember the clearances i used off hand. If you need help talk to john cope at cope racing transmissions. I was hurting the trans and breaking stuff almost every time out before he set me up with what i have now. Great guy to buy parts off or and get advise. http://www.coperacingtrans.com/
[Re: JohnRR]
#4086
10/05/03 10:18 PM
10/05/03 10:18 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
I just installed the new Coan 16 element roller in my 727 (had pics on moparts a week or so ago) and should have some real world info on this and some other heavy duty pieces including using different clutch and Kevlar band materials and installing a lo pressure band apply valve body from pro trans which in the next month or so will be swapping back to back at the track with my non band apply hi pressure Griner brake to see really whats what. Also will be trying out new dynamic 9" converter that Frank Lupo said should only slip about 3% with a 5600 stall(worth it's weight in gold if it's true !). Greg Z, nice meeting you over at the Mopar show at Moroso, i broke my converter before first round and it hurt the trans so now i am on a quest to building the heavyist duty 727's with no breakage to run Top Sportsman (7:99 or quicker index), also my buddy that just bought Larry Morgans Neon has same setup in his trans and i'll keep thread posted as we find any weak links, otherwise 440 Jim has been doing an excellent job with his web site with great information. Randy
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
#4089
10/06/03 08:44 AM
10/06/03 08:44 AM
Posts: 6,148 Melbourne , Australia
LA360
This is a bit of a stretch for me to remember, I know with the 904 front drum, you have to pay attention to the clutch clearances, from memory what Jim said about the clearances was basically on the money. 5 clutches in the front drum is a must in anything over say 450-500ft/lbs in a 904, There are a couple of other things , but I will have to go through my notes from when we did our last trans. I will definately be keeping a close eye on this thread, and hopefully it makes it to the archives. AL...
Alan Jones
