Page 3 of 3 1 2 3
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: 70Duster360] #39743
08/21/07 09:20 PM
08/21/07 09:20 PM
North Dakota
Jesse_Lackman Offline OP
super gas
super gas
North Dakota
Jesse, how much would a pair of those heads cost setup that way?
Your best bet would be to check with Hughes Engines ( www.hughesengines.com ) or FBO ( www.4secondsflat.com ), each offer the EQ head in different flavors. I'm low volume and the cost of shipping heads alone takes me out of the game. I'd rather do complete engines.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39744
08/22/07 08:50 AM
08/22/07 08:50 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Actually a lot could have been done to make bigger numbers if that was the objective - I had a modified M-1 intake to try but no time, and yes the headers were small. The reason for that though was the customer was going to run full exhaust and 2 3/4 collectors was closer to what the in car senario would be.
Good info on the differences between the RHS and the EQ. The RHS is wider at the pushrod crossection of the intake port pair. That means the intake port window at the pushrod pinch can be larger on the RHS. I was trying to get RHS to cast a version of this head with machined pushrod holes which would open up the option of machining them wider for use with offset intake rockers. But it's like Ross Perot said of GM, "It is easier to get an elephant to tap dance than get a big company to make a change."
are RHS mag heads still being produced? I never see them anywhere....
2017 Grand Cherokee Overland
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: patrick] #39745
08/22/07 09:06 AM
08/22/07 09:06 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Patrick, I got mine on clearance from comp cams so I would guess they quit makeing them. There e-bay company is speed liquidators.
David
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: HotRodDave] #39746
08/22/07 10:38 AM
08/22/07 10:38 AM
Kansas wishing I was in Ohio
SeanD Offline
SeanD  Offline
I contacted RHS several months ago about these heads and was sent a reply that at that time they were not producing them at that time but they were looking into "possibly" producing them in the future.
Unfortunately I deleted the reply or I would have cut/pasted it here.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: SeanD] #39747
12/31/07 10:25 PM
12/31/07 10:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Jesse did this motor ever end up in the car? If so how did it run?
Also you said "Good info on the differences between the RHS and the EQ. The RHS is wider at the pushrod crossection of the intake port pair. That means the intake port window at the pushrod pinch can be larger on the RHS. I was trying to get RHS to cast a version of this head with machined pushrod holes which would open up the option of machining them wider for use with offset intake rockers. But it's like Ross Perot said of GM, "It is easier to get an elephant to tap dance than get a big company to make a change." "
Could I just have an even bigger hole machined into these and then sleeve them to get a little more pinch cross section?
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: HotRodDave] #39748
01/01/08 10:27 AM
01/01/08 10:27 AM
North Dakota
super gas
super gas
North Dakota
Groan, I wish! I was communicating with Peter Hill of Southern Performance NZ which was the factory for the RHS/Comp heads. His e-mail doesn't work anymore but I think he still works for Southern Performance/RHS. What I suggested was to cast a wide intake port pair and machine in the pushrod holes, that would open up the option of machining them in anywhere thus allowing a much wider pushrod pinch cross section if you used offset rockers. Peter was very receptive to the idea of one casting and machined options but the unknown interest in a iron head like that was the question.
What I thougt would sell was a head that would work with;
either LA or magnum valve covers
either LA or Magnum rocker gear
either LA or Magnum intake manifolds
eithr pushrod or shaft oiling
and have the RHS 360HPST chamber and ports.
RHS is updating their cast iron heads and might get to the Magnum yet, I'm not too hopefull anymore though.
Might be better to try to get EngineQuest to do it.
I don't think the engine is running in the car yet.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39749
01/01/08 11:59 AM
01/01/08 11:59 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I see they do have more room to go up and down on these heads than the factory or EQ heads, would it help to just make the roof and port floor taller like a LS chevy port? I can see getting .250 more inches port hight (.125 up and .125 down) over the other heads and you could get more cross section through the PR pinch. I wish I could afford to send these to a real porter to get some real world info on them.
As for re-introduceing these with a few up grades for about the same price that would be a great idea. These are nicer than the EQ head already. It would only take a small tweak to be able to use different valve covers and most or the differance in shafts and pedestal rockers can be done by machine work like mopar does with the aluminum magnum and comandoes. Even the LA and mag intake setup just needs a little different machining. They may be able to do this already (I am scared to try it) make the spring seat where it can be machined down .200 so we can use LS chevy springs with out buying fancy valves and screwing up the geometry. I actually think valve selection is the biggest deterent to people useing these, by the time you buy custom valves you start gettin closer to the cost of a eddy and if you put a thicker stem valve in you lose flow and gain valve weight.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: HotRodDave] #39750
01/01/08 12:16 PM
01/01/08 12:16 PM
North Dakota
super gas
super gas
North Dakota
You don't need custom valves, I'm using standard 11/32 "chevy" valves in these heads with + retainers and/or locks and can get 1.75 - 1.8 installed height springs in them. Thus I'd say leave the spring seats alone and get Jim Miller to do a Magnum rocker arm to take care of geometry problems.
The geometry was fairly good on the 520/408 though.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39751
01/01/08 12:33 PM
01/01/08 12:33 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
10.8 CR
Actually made slightly more power on 91 pump than 100LL
Total timing = 35
Who's pistons? Are they standard off the shelf? I need a set around that CR for standard LA with 4.0" stroke in a 340 I a building.
That's awesome, and looks very similar to a build I am working on.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Dragula] #39752
01/01/08 12:38 PM
01/01/08 12:38 PM
North Dakota
super gas
super gas
North Dakota
CP pistons, I think they are a shelf 408 piston, the dish didn't quite match the RHS chamber.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39753
01/01/08 01:25 PM
01/01/08 01:25 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I have never heard of the rhs iron heads??? I spent alot of time porting my EQ heads and I like them and the price was right. The pushrod pinch is less than on the regular magnum heads but still looks like a restiction for higher HP engines. I removed a small amount of material from the pinch and it would be nice to be able to get a magnum style head with an offset rocker and eliminate that pinch.......
You made some great power and torque numbers and I hope my 390 surprises me as I have a similar setup with a little less cam/compression. TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: tpabayflyer] #39754
01/01/08 01:40 PM
01/01/08 01:40 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
those are GREAT numbers!!!!...im kind of curious what KEVIN@HUGHES wanted??
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: MIKES_DUSTER] #39755
01/02/08 09:27 AM
01/02/08 09:27 AM
North Dakota
super gas
super gas
North Dakota
They were wondering about testing one of their modified intakes on that engine when it was on the dyno. That would have been very interesting but the dyno testing was already done.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39756
01/02/08 10:08 AM
01/02/08 10:08 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
All magnum based heads except eddys have an 8mm stem so you still can not just drop those valves in there and they are thicker makeing more weight and slightly restrictin flow.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: HotRodDave] #39757
03/04/09 09:19 PM
03/04/09 09:19 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I may have dreamed this but I don't think so. I was thinking my buddy did a set of ported magnums with 2.00 LS1 valves.
Getting old just means you were smarter than some and luckier than others.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: dannysbee] #39758
03/05/09 09:46 AM
03/05/09 09:46 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
LS1's are also 8mm stem.
Re: Street 360/408 dyno results (520 CHP - 540 CTQ) [Re: Jesse_Lackman] #39759
03/05/09 10:32 AM
03/05/09 10:32 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
RHS™ Indy 360 X Cylinder Heads
RHS™ airflow specialists team up with Chrysler experts at Indy Cylinder Head to develop powerful cast iron replacement head for Small Block LA & Magnum applications
Thanks to the combined efforts of RHS™ and Indy Cylinder Heads, Mopar enthusiasts will finally get the performance small block head they deserve. A cast iron replacement, the RHS™ Indy 360 X Head series is designed for both Small Block LA and Magnum applications (318-360-415cid). With a host of additions and improvements over the factory originals, these heads are an easy way to get 400 to 550 horsepower out of your Mopar-powered street machine.
Features of these impressive heads include 179cc intake and 67cc exhaust runners, a 62cc combustion chamber, hardened multi-angle intake and radiused exhaust valve seats, an improved valve guide design and a highly efficient water jacket to prevent engine hot spots. The RHS™ Indy 360 X Cylinder Heads also come with an extra thick deck surface to enable angle milling for compression. The 360 X series is divided into two sub-series: the LA-X for Chrysler LA-style engines and the MA-X for Magnum applications.
The LA-X head uses the standard intake manifold and rocker shaft. It is drilled for the proper valve cover and gasket and contains both Chrysler LA and Magnum accessory holes on both ends of the head. Designed for use with the Magnum intake manifold, rocker arms, and valve covers, the MA-X head is the second option of the RHS™ Indy 360 X series and features a Magnum pedestal that is large enough to enable 7/16”-14 drilling and tapping for use with stud-mounted rocker arms and guide plates. Both sub-series are designed for use with 8mm intake (1.92” diameter) and exhaust valves (1.625” diameter).
For more information about the RHS™ Indy 360 X Cylinder Heads or any other RHS™ product, call us at 1-877-776-4323, or visit us online at www.racingheadservice.com.
Quick Summary
Product: RHS™ Indy 360 X Cylinder Heads
Part Number: #20300 (MA-X); #20301(LA-X)
Features & Benefits:
• Performance heads available for both Small Block Chrysler LA & Magnum engine applications
• 179cc intake/67cc exhaust runners & 62cc combustion chambers
• Hardened multi-angle intake (1.92” dia.) & radiused exhaust (1.625” dia.) valve seats
• Dual pattern exhaust bolts (standard & W2) & improved valve guide design
• Highly efficient water jacket with extra thick deck faces
Visit RHS Website
Sign-up For RHS News & Product Specials
20301-640-.jpg.jpg Views: 24 Size: 124.9 KB ID: 654
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39760
03/05/09 05:35 PM
03/05/09 05:35 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
It was dropping off at 6200, the customer didn't want to run it higher. It may have been lifter pump up, the preload was about 3/4 turn. I thought about putting heavy duty c-clips in the lifters and running less preload but we didn't have the time.
The drop off might have been the engine going out of tune as far as intake/cam/headers it might have been an RPM they didn't like. I think that is more likely as it sounded good, no misfiring. We have run the stock Magnum lifters at higher RPM on the IMCA V-6.
The dual plane Performer RPM seems to be more prone "going in and out of tune" when compared to a single plane. I had an M-1 ready to test but again didn't have the time.
What has been you experience with an upper RPM limit with the stock hydraulic roller lifters?
Hey jess , sounds like you got to test the heads , We gained about 300 rpm on one of daves hyd rollers by taking almost all the preload out and running just to the clips ,went from 6500 to 6800 ,I think we had 5 degrees more @ .050 also, We were running crane hyd roller lifters with v links / Craig
Page 3 of 3 1 2 3
