Page 1 of 3 1 2 3
Street 360/408 dyno results (520 CHP - 540 CTQ) #39703
05/17/07 10:53 PM
05/17/07 10:53 PM
North Dakota
Jesse_Lackman Offline OP
super gas
super gas
North Dakota
408 based on Magnum block
-RHS 360HPST iron heads, 2.02/1.60
-Hughes 236/242 @ .050 Hyd roller .557/.521 lift
-stock Magnum hydraulic lifters
-Dove/Racer brown rockers 1.6 intake 1.5 exhaust
-Performer RPM Air Gap
-Holley 870 Street Avenger
-1 5/8 x 2 3/4 dyno headers
-91 octane pump gas
-12.5 manifold vacuum @ 950 RPM
-398 CTQ @ 2000 RPM
-542 CTQ peak @ 4300 RPM
-520 CHP peak @ 5900 RPM
-500 CTQ from 3200 to 5200 RPM
No time to try any tricks, would have made more upper RPM HP with an open spacer but customer did not have the room to use one.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39704
05/17/07 11:12 PM
05/17/07 11:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Thats great for iron heads.
What was done to those heads?
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: HotRodDave] #39705
05/18/07 12:39 AM
05/18/07 12:39 AM
Yea i would like to know what was done with the heads! Thats basically my combo in a nutshell, and i am running unported irons....i expect way less from my build!
Re: Street 360/408 dyno results (RHS 360-HPST heads) #39706
05/18/07 09:21 AM
05/18/07 09:21 AM
North Dakota
super gas
super gas
North Dakota
Blending to valve job, guide work, (they don't need much though), and opening up the pushrod pinch.
The heads are a big part of the package.
Lot of thought and planning into this one and it paid off.
In case it comes up my dyno doesn't seem to be an overly optimistic one and has been cross checked three ways; jet boat pumps, it takes X hp to turn a certain pump X RPM - it was right on; quarter mile track time HP pretty much equal to dyno; and the 2003 Moparts EM engine results very close to mine.
I'll probably hear track times for this engine later this summer.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39707
05/18/07 09:24 AM
05/18/07 09:24 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
thats alot of power down low!
nice!!
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39708
05/18/07 09:32 AM
05/18/07 09:32 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What was the compression ratio?
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: HotRodDave] #39709
05/18/07 09:35 AM
05/18/07 09:35 AM
North Dakota
super gas
super gas
North Dakota
10.8 CR
Actually made slightly more power on 91 pump than 100LL
Total timing = 35
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39710
05/18/07 09:48 AM
05/18/07 09:48 AM
SoCal
Brian Hafliger Offline
SoCal
Yeah, hopefully someone doesn't try to ruin this thread with the "your dyno must be Happy" scenario.
Great power, gotta love those iron heads
Brian Hafliger
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39711
05/18/07 10:34 AM
05/18/07 10:34 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Gotta love those results...
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: BradH] #39712
05/18/07 02:19 PM
05/18/07 02:19 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Do you have flow numbers for those heads?
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Pat7272] #39713
05/18/07 04:13 PM
05/18/07 04:13 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
nice. are the RHS heads still available? how do they compare with the enginequest ones (which I see all over the place compared to the RHS's).
how much do you think a hydro roller cam with ~8 degrees less duration would do for power, torque, & idle? I'd like to build something similar, but I'd like ~ 16" vacuum at a 900-950 idle.
2017 Grand Cherokee Overland
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: patrick] #39714
05/18/07 05:19 PM
05/18/07 05:19 PM
North Dakota
super gas
super gas
North Dakota
8 degrees less cam would likely take 25 peak HP but the torque peak might stay close to the same.
- No flow numbers on the heads.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39715
05/18/07 08:32 PM
05/18/07 08:32 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
how do these heads compare to the Edelbrocks?
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39716
05/19/07 07:20 AM
05/19/07 07:20 AM
Johnstown ohio
BluCuda Offline
BluCuda  Offline
Johnstown ohio
Hi Jesse- Good job! Sounds like a nice street/strip engine. What was the cams lobe center angle and what intake centerline did you install it at?
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: BluCuda] #39717
05/19/07 12:31 PM
05/19/07 12:31 PM
North Dakota
super gas
super gas
North Dakota
Haven't run the RHS/ProTopline 360-HPST back to back against Edlbrocks.
Cam 112 LSA installed at 110.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39718
05/19/07 03:17 PM
05/19/07 03:17 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Are those heads factory pieces that have been reworked or brand new castings?
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39719
05/19/07 04:40 PM
05/19/07 04:40 PM
I have a pair of these RHS (cast iron) Magnum heads new on the shelf. In case anyboby is interested.
Andy
305-608-2565 Cel.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39720
05/19/07 05:37 PM
05/19/07 05:37 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Nice job Jesse
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Pat7272] #39721
05/21/07 12:14 AM
05/21/07 12:14 AM
North Dakota
super gas
super gas
North Dakota
Brand new castings They have been out for a while though.
Re: Street 360/408 dyno results (RHS 360-HPST heads) [Re: Jesse_Lackman] #39722
05/21/07 08:32 AM
05/21/07 08:32 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
most promising thing is the amount of lift/ramp angle and RPM the stock lifters were able to handle
Page 1 of 3 1 2 3
