Street 360/408 dyno results (520 CHP - 540 CTQ)
#39703
05/17/07 10:53 PM
05/17/07 10:53 PM
Posts: 752 North Dakota
Jesse_Lackman
super gas
super gas
North Dakota
408 based on Magnum block
-RHS 360HPST iron heads, 2.02/1.60
-Hughes 236/242 @ .050 Hyd roller .557/.521 lift
-stock Magnum hydraulic lifters
-Dove/Racer brown rockers 1.6 intake 1.5 exhaust
-Performer RPM Air Gap
-Holley 870 Street Avenger
-1 5/8 x 2 3/4 dyno headers
-91 octane pump gas
-12.5 manifold vacuum @ 950 RPM
-398 CTQ @ 2000 RPM
-542 CTQ peak @ 4300 RPM
-520 CHP peak @ 5900 RPM
-500 CTQ from 3200 to 5200 RPM
No time to try any tricks, would have made more upper RPM HP with an open spacer but customer did not have the room to use one.
Re: Street 360/408 dyno results (RHS 360-HPST heads)
[Re: Jesse_Lackman]
#39704
05/17/07 11:12 PM
05/17/07 11:12 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Thats great for iron heads. What was done to those heads?
[Re: HotRodDave]
#39705
05/18/07 12:39 AM
05/18/07 12:39 AM
Yea i would like to know what was done with the heads! Thats basically my combo in a nutshell, and i am running unported irons....i expect way less from my build!
[Re: Jesse_Lackman]
#39708
05/18/07 09:32 AM
05/18/07 09:32 AM
HotRodDave
Kalispell Mt.
What was the compression ratio?
[Re: Pat7272]
#39713
05/18/07 04:13 PM
05/18/07 04:13 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
nice. are the RHS heads still available? how do they compare with the enginequest ones (which I see all over the place compared to the RHS's).
how much do you think a hydro roller cam with ~8 degrees less duration would do for power, torque, & idle? I'd like to build something similar, but I'd like ~ 16" vacuum at a 900-950 idle.
[Re: Jesse_Lackman]
#39719
05/19/07 04:40 PM
05/19/07 04:40 PM
I have a pair of these RHS (cast iron) Magnum heads new on the shelf. In case anyboby is interested.
Andy 305-608-2565 Cel.
[Re: Pat7272]
#39721
05/21/07 12:14 AM
05/21/07 12:14 AM
Jesse_Lackman
super gas
super gas
North Dakota
Are those heads factory pieces that have been reworked or brand new castings?
Brand new castings They have been out for a while though.
