Re: Myth of Orange Peel!
[Re: Marq]
#38854
07/23/09 02:30 PM
07/23/09 02:30 PM
Posts: 246 middleOnowhere CA
THEYOUNGGUN53
middleOnowhere CA
I also use two rags.
thank you for the advice guys, I'll try it and see if it works.
a car is never "done"
[Re: THEYOUNGGUN53]
#38855
07/23/09 03:32 PM
07/23/09 03:32 PM
I am finishing a fiberglass hardtop for my MGB. I'm doing it on a budget, so I've been investigating roll on/brush on methods in lieu of a $400 professional spray. I don't have any spray equipment myself.
This forum has confirmed my research on Interlux topsides paint as a possibility.
I've had some concerns that the final coat will show brush marks and lint/hair/etc. unless I wet sand and polish after the final coat. However, Interlux technicals advise not to wet sand or polish the final coat, or I will damage the finish and destroy the gloss. Reading through the forums, I find that some do final wet sanding, some do not with the Brightsides paint. Do you have any experience with wet sanding these marine paints?
I was thinking to use the two part Perfection, as I thought it would look better, and be a more durable finish for a hardtop that is being taken on and off the car fairly frequently. But after reading the forums, I'm not sure any more. Cost difference is not an issue, as I'm not using much paint on the top. Is Brightsides adequate? Has anyone experience in wet sanding the final coat of the two part system?
I was also thinking that the two part system, at least the primer phase, would be better for refinishing of an old fiberglass (gelcoated) top to stabilize the surface. Am I being paranoid?
[Re: kenzo42]
#38858
07/25/09 10:11 AM
07/25/09 10:11 AM
Posts: 575 Canada
Marq
mopar addict
mopar addict
Canada
Has anyone here used a Porter Cable 7424 for correction of paint after wet sanding?
I'm curious to see some sample of this.
I LOVE my Porter Cable 7424... and I use it whenever I am bored and looking for a fun way to kill an hour polishing my cars ![](/ubbthreads/images/graemlins/wink.gif)
I don't really understand what you mean by 'correction' of paint after wet sanding.
If your wet sanding has not gotten the painted surface smooth enough... about the only use the P&C would be... is if you slapped the wooly bonnet on it and used it to try to further smoother the surface.
But what you must remember is that to go from a completed paint job to a finished product.... you go through the wetsanding stages by using finer and finer grit sand paper. The whole point being that you are improving on the smoothness of each previous level of sanding.
Normally... the Porter Cable comes to work once you have finally used sand paper at the highest grit level and the sand paper can no longer improve on the smoothness of the painted surface.
Or a simply way of looking at things... the sand paper... through the various grits... takes you from 800 grit... up to 2000 grit. AND the Porter Cable is simply a further refining of the grit you are throwing at that surface to smoothen it... So the P&C is going from 2000 grit and up to a possible maximum of 4000 grit ( depending on what type of product you are applying to the painted surface - ie rubbing compound or polish )
Clarification : just remember that a "polish' is simply a further higher level of 'gritiness' and should not be mistaken for the 'waxing or protective stage'. Manufacturers are too blame for the confusion between polishing products and waxing products.
BUT if your painted surface is sitting at roughly the appearance of an 800 grit... well it is kind of useless trying to put the P&C to work using its 2000 to 4000 grit to try to knock back the 800 grit.
Now, I have heard of some folks who swear that by using the 'wooly bonnet' on their paint... they are able to get a more agressive polishing of the surface. So for arguments sake, let us just specualte or guess that the wooly bonnet is providing say a 1000 or 1500 'grit equivalent'.
So the 'wooly bonnet' might be useful to go nuts on an 800 grit equivalent surface and rapidly get it to a 1000 or 1500 'grit equivalent'. BUT the warning here is that because it is more agressive then a 'wet sanding'... you run the risk of literally polishing away your paint IF you allow the polisher to remain on one spot too long. So it is do-able, but you must take great care when doing it.
As for me... I would tend to think that the P&C's greatest charm and benefits come when you are using it to :
a ) applying a rubbing compound ( like the Turtle Wax rubbing compound - the murky brown clay looking stuff - or something like the 3m or other manufacturer type 'rubbing compounds'. At this point the 'rubbing compound is providing the equivalent to a 2000 - 3000 grit equivalent - and is really just further enhancing the smoothness of the surface.
b ) applying a good quality polishing compound which is simply taking things to yet a higher level of fine gritiness ( let's say from 3000 to 4500 grit )
c ) applying a good quality waxing compound, which should have no gritiness to it... but instead is attempting to seal the painted surface and lay down a protective barrier on to the paint to keep the Ultraviolet out, the oxygen out, water out and repel any other crapola that might land on the paint.
One thing you need to watch for, as you shop the aisles at your local automotive shop for rubbing compounds, waxes and polishes is to read carefully what each of the products is designed to do by the manufacturers.
For example, there are a lot of 'hybrid' products out there that 'try' to make your life easier by combining two aspects of the task together. For example... a wax with a cleaner, or a wax with a polish, or inversely a polish with a wax etc.
In your mind....... as you pick the products or even the method by which to apply them, you have to visualize how each of those products are helping you to progress further towards achieving the absolute smoothness of the surface that fits with your level of patience ![](/ubbthreads/images/graemlins/wink.gif)
So I hope this long winded explanation touches on some things and explains the process better, so that you can bring about your own conclusion on whether the Porter and Cable should be deployed at a certain stage to accomplish some 'corrective' measure.....
The simple and short answer would be " IF you figure that the finish needs to be additionally tweaked to get it smooth... the odds are that the easiest answer probably rest with choosing the proper grit of sand paper and doing some further wet sanding.... and to save the Porter and Cable for the finishing tweaking of the surface to maximize its final smoothness.
Re: New Paint job on a budget thread Part III
[Re: 69DartGT]
#38866
07/29/09 10:47 PM
07/29/09 10:47 PM
THEYOUNGGUN53
middleOnowhere CA
you are correct, at one point I will be doing the whole car evenly. You see I started out just as a test, but then I got a little...carried away ![](/ubbthreads/images/graemlins/image_294343.gif) I started painting before I compleated all the body work, which is why I haven't been able to paint it all at once.
[Re: THEYOUNGGUN53]
#38867
07/31/09 04:18 PM
07/31/09 04:18 PM
First off, this thread is awesome!
Im ready to start my paint process and am trying to find (non-odorless) mineral spirits.
Ive been to 4 stores and everyone carries ODORLESS MS.
From the hundreds of pages that Ive read it says the regular MS produces better results.
Should I just get the odorless MS?
[Re: 69DartGT]
#38870
08/01/09 11:28 AM
08/01/09 11:28 AM
I am new here and a Chevy owner (69 Chevelle). Just looking for opinions on the color combo. When I got the car in 85 it was black/parchment. I am thinking about putting it bac to factory Dover White/Parchment, but am not sure if I like the combo. Had the body off, new quarters, fenders, and it is an original SS car with the original #'s matching standard bore engine/trans/rear end. I mixed up some Rustoleum white and almond to match the factory color. Please click on the link below. http://barry13.winkflash.com/
#38873
08/01/09 04:22 PM
08/01/09 04:22 PM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
Barry, I would say that all depends on what you want for the look of the car. All though it is a numbers matching car, my guess is you aren't concerned with overall value since you are using the rustoleum roll-on approach to painting it. In my opinion, white is such a bland color. I would say paint it however you want, just make it look good. BTW, I may be a Mopar guy myself, but my first car was a 68 Chevelle. ![](/ubbthreads/images/graemlins/thumbs.gif)
