Re: Fuel Tank vent lines? B body
[Re: 440challenger]
#387226
07/26/09 09:43 PM
07/26/09 09:43 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
I believe you bought a sending unit that can be used for fuel injection as well. I did the same thing for my 69 Coronet 500. I just blocked the extra line off with a small piece of hose and a clamp around a bolt.It worked fine.
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
[Re: Joshs68]
#387228
07/27/09 12:45 AM
07/27/09 12:45 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
One line goes to the vapor line that is supposed to be in the trunk and then goes back down, the other one goes to a short stub line that goes to the shock crossmsmber and is also a vent. If the tank is not vented it will implode as you suck the fuel out. the second line from the sender is the return line from the filter on the engine, and is used on Hemi and 440 cars. Here is pic someone posted on Moparts of their install.
[Re: 440challenger]
#387230
07/27/09 07:32 AM
07/27/09 07:32 AM
Posts: 537 Charlotte, NC
Kowal
Charlotte, NC
It matters a lot, hook them up backward and you get fuel draining out of the lines when your tank is better than half full. Go to the "lift off hood forum", there is a whole string on this... http://a12mopar.com/yabb/YaBB.pl?num=1238949100
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: meepmeep70]
#387234
08/03/09 12:15 AM
08/03/09 12:15 AM
sthemi
Chicago Burbs
How is this?
NOT MY PHOTO, found on internet
[Re: sthemi]
#387235
08/03/09 12:22 AM
08/03/09 12:22 AM
sthemi
Chicago Burbs
And this?
Again not my photos
This one also looks replaced and I dont think the sender wire is going thru exactly the right spot.
[Re: sthemi]
#387236
08/03/09 07:38 AM
08/03/09 07:38 AM
Posts: 4,503 NJ
440challenger
NJ
[Re: sthemi]
#387237
08/03/09 05:42 PM
08/03/09 05:42 PM
Posts: 2,410 Wichita,KS
Blakcharger440
Wichita,KS
The new fuel tank in my 70 charger does not have those 2 vent lines on the driver side of the tank....but it does have another port coming out near the bottom of the sender. I have that one plugged off.
Is that going to cause a problem?
[Re: Blakcharger440]
#387238
08/05/09 07:09 PM
08/05/09 07:09 PM
Posts: 34 Conn.
b5 69
Conn.
On a 69 road runner the gas vent closest to the driver side goes up into the trunk,the line runs across the floor does a semi loop then appears to go back out through the floor,as in the b body pics above, yet when I look from the under side I can't see where this line goes Where does it go ? Does it end where it goes back into the floor? Am I missing something? Thanks ,jeff
[Re: b5 69]
#387239
08/05/09 07:47 PM
08/05/09 07:47 PM
sthemi
Chicago Burbs
Yes, It is simply vented to the air just below where it passes thru the floor. That is why parking an old car in an attached garage on a hot day, will not be a pleasant experience, especially with today's nasty gas..
[Re: b5 69]
#387240
08/05/09 11:17 PM
08/05/09 11:17 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The line goes through a rubber grommet & dumps the fuel vapor inside the frame rail where it seeps out of the holes punched in the bottom of the rail...
