Help!! 02 Neon Subframe bolt spinning #387185
07/26/09 09:10 PM
07/26/09 09:10 PM
Hillsdale,Mi
69swinger340 Offline OP
Hillsdale,Mi
I am trying to replace the control arm bushings on an 02 Neon. On the rear control arm bolt the nut is spinning in the frame. What is the least painful way to fix this?
*69 swinger 340 4spd *70 T/A 340+6pk 4spd
Re: Help!! 02 Neon Subframe bolt spinning [Re: 69swinger340] #387186
07/26/09 10:56 PM
07/26/09 10:56 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
Cut some slots in the frame rail (on side,outer side) in the shape of a u and bend it up. Then you can put a wrench on nut (will probably need to be heated) and get bolt out. When done bend peice back down and weld it up. Happens quite often.
Re: Help!! 02 Neon Subframe bolt spinning [Re: mod381] #387187
07/27/09 01:50 AM
07/27/09 01:50 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Use a die grinder or dremel with a cut off wheel and make a window, you may be able to use the cut off wheel to cut the bolt off as well.
Be sure to reweld the repair.
