Tail light sockets/ or LED replacements? #387108
07/26/09 06:59 PM
07/26/09 06:59 PM
Andrewh Offline OP
Andrewh  Offline OP
I decided to rewire the tail lights in my 65 coronet.
Anyone know where I can buy new sockets? Both for the tail lights and reverse.
Also anyone recommend any LED replacment's, or even a wired in one now that I am rewiring?
Re: Tail light sockets/ or LED replacements? [Re: Andrewh] #387109
07/26/09 07:16 PM
07/26/09 07:16 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
I like the 5 mm 1/4watt super bright undiffused LED side markers.
The original bulbs work fine too. LEDs last longer an are more shock resistant.
Re: Tail light sockets/ or LED replacements? [Re: mark7171] #387110
07/26/09 08:08 PM
07/26/09 08:08 PM
Andrewh Offline OP
Andrewh  Offline OP
have a source for them?
Re: Tail light sockets/ or LED replacements? [Re: Andrewh] #387111
07/27/09 08:55 PM
07/27/09 08:55 PM
Andrewh Offline OP
Andrewh  Offline OP
btt
Re: Tail light sockets/ or LED replacements? [Re: Andrewh] #387112
07/29/09 04:59 PM
07/29/09 04:59 PM
East TN.
Moparsky Offline
Moparsky  Offline
East TN.
Hi Andrewh,
Ran across this company(HITECH)that makes an LED conversion kit for your 65 Coronet, not cheap at $180. It uses the same bayonet lamp mount you now have. Ask them if you'll need a "load equalizer" so your flasher will be able to blink the LED's.
Each assembly has 87 LEDs, guess you would have to seperate the lense from the housing to install this...
http://www.hitechledproducts.com/product...7cf914971c13983
HITECH's cheaper LED bulb conversions:
http://www.hitechledproducts.com/index.php?cPath=26_30&osCsid=33812d1a552415f707cf914971c13983
You might look at this company as well:
http://www.superbrightleds.com/tail-brake-turn.html
Hope this helps,
John
Re: Tail light sockets/ or LED replacements? [Re: Andrewh] #387113
07/29/09 07:01 PM
07/29/09 07:01 PM
Canada
Mr_Heaterbox Offline
Canada
Hi I restore tail light and park light housings. You can get really nice generic sockets at many auto parts stores. I am in Canada so the following doesn't really help you I assume, but Canadian Tire has some superb ones that fit in really nice and have good plating and look quite close to originals. With work you can even duplicate the weather seal jacket typically used on many front turn signal/park lights. Hope that helps
Brent
www.MrHeaterbox.com
www.PremiumDashDecals.com
Re: Tail light sockets/ or LED replacements? [Re: Mr_Heaterbox] #387114
07/29/09 08:47 PM
07/29/09 08:47 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks.
The tail lights seperate pretty easy.
Not really worried about originality.
Thought I might even go junk yarding. Saw quite a few cars today with oem led lights.
