timing issue #386948
07/26/09 05:21 PM
07/26/09 05:21 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
The timing has been moving around on my car, i've checked the balancer which seems ok, the distributor is brand new MSD, i've inspected the bronze drive and it appears ok.
I am wondering if it could be the small bush in the block because i can twist the rotor arm quite a lot, how much movement should there be?.
When i put the timing light on it, it's jumping all over the place.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: timing issue [Re: deaks] #386949
07/26/09 05:38 PM
07/26/09 05:38 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what about the timing chain?
Re: timing issue [Re: Quicktree] #386950
07/26/09 05:49 PM
07/26/09 05:49 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I tried turning the motor over with a long bar and as soon as i turn it the rotor moves instantly.
best 60ft 1.36
Re: timing issue [Re: deaks] #386951
07/26/09 06:00 PM
07/26/09 06:00 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Rock the bar back and fourth to see if its the chain
Re: timing issue [Re: emarine01] #386952
07/26/09 06:02 PM
07/26/09 06:02 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Ok will try that, could it be the small bushing though and how much twist should there be in the rotor arm.
Mick
best 60ft 1.36
Re: timing issue [Re: deaks] #386953
07/26/09 06:06 PM
07/26/09 06:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s one of the reasons I locked my dizzy out.....one less thing to mess with and if you have a fast curve in it, it will jump around.
Re: timing issue [Re: Thumperdart] #386954
07/26/09 06:12 PM
07/26/09 06:12 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
There have been posts on here about timing moving around caused by the play between the dist shaft and oil pump drive slot, seems its fixed with a clamp or short hose
Re: timing issue [Re: deaks] #386955
07/26/09 06:22 PM
07/26/09 06:22 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
[how much movement should there be?.]
i had .090 movement and took it down to .010 with the lock coller and welding the tip of the dist shaft.
Re: timing issue [Re: blownzoom440] #386956
07/26/09 06:42 PM
07/26/09 06:42 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I had a short tube on the last distributor and i flattened the tang on both sides a little to make it a comfortable fit in the slot.
Going back to my original question, could the bush possibly cause a problem.
best 60ft 1.36
Re: timing issue [Re: deaks] #386957
07/26/09 06:51 PM
07/26/09 06:51 PM
ELYRIA,OH
ELYRIA,OH
no. my
Re: timing issue [Re: deaks] #386958
07/26/09 06:55 PM
07/26/09 06:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not by much at all... if the bushing is worn you
still wont get rotational play, you would get the
shaft moving side to side... if the chain is tight
then its down to the cam walking back and forth,
the intermediate shaft moving up and down or a dist
problem (binding then going free)
Re: timing issue [Re: blownzoom440] #386959
07/26/09 06:58 PM
07/26/09 06:58 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
yes
if its out of round and there is play in it, oversized to the shaft
it gave me problems
repaced it and with locked timming *35 needed to get a msd start retard box
1.39 9.85 - 137 mph
Re: timing issue [Re: Ari440] #386960
07/27/09 03:17 AM
07/27/09 03:17 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Ari
Did you replace it with the motor together, i presume it's pump off and tap it out with a rod from underside and long nose pliers to pull it out the top.
When i fitted the MSD dist, i didn't fit the rubber hose back on and the car lost 3-5 mph at the weekend.
The only other changes since the previous meeting are a larger rad and i've changed the electric fan for a viscous fan.
Mick
best 60ft 1.36
Re: timing issue [Re: deaks] #386961
07/27/09 09:08 AM
07/27/09 09:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ari
Mick
If you want to change the bushing while the engine
is still together, make up a J on a slide hammer to
pull it out (go down through the center of it)
Re: timing issue [Re: MR_P_BODY] #386962
07/27/09 09:15 AM
07/27/09 09:15 AM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
What a great idea, thanks Mr P I knew i could rely on you.
I want to change the bush but i'm also going to buy a dist collar and maybe look into another bronze drive.
How would i know if i had cam walk, cam is a crane roller.
Mick
best 60ft 1.36
Re: timing issue [Re: deaks] #386963
07/27/09 09:35 AM
07/27/09 09:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Mick
Take a big screwdriver and in the dist hole move the
cam back and forth... I think the spec is like .010-.015
but I'm not sure on that.... you know what that looks
like so if it moves a fair bit you need to correct, but
that turns the intermediate shaft more or less as
the cam moves fore and aft
Re: timing issue [Re: deaks] #386964
07/27/09 11:43 AM
07/27/09 11:43 AM
Pull the distributor out and pull the oil pump drive up enough so you can try and rock the shft in the bushing, if it has a bunch of lateral movement then check the shaft diameter and the bushing.Is yours a aluminum or bronze looking bushing? As far as cam movement it is a lot easier to move the cam back and forth with a screwdriver or anty other type of lever if you remove the pressure from the valve springs first
Re: timing issue [Re: deaks] #386965
07/27/09 05:42 PM
07/27/09 05:42 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Ari
Mick
YES
I did it with the moter in the car
GOT A LONG 5/8 BOLT .... 7/16 THREAD AND THREADED IT IN THE BUSHING AND PRYED IT OUT SLOWLY
HAD THE MANIFOLD OFF AND VALLY PLATE TOO
this was when I went to 12.5 comp and 613/276 cam upgraded the from 9.1 528 solid
timming was skattering all over ,when I changed the bushing it was steady but hard to start and put a retard box in for stating the moter over easy
1.39 9.85 - 137 mph
Re: timing issue [Re: Ari440] #386966
07/27/09 06:14 PM
07/27/09 06:14 PM
ELYRIA,OH
ELYRIA,OH
Ari
Mick
YES
i would think the distrebutor could help hold the intermediat shaft in line.the intermediat shaft must have been like throwing a hotdog down the hallway. anything can happin i guess.
Re: timing issue [Re: blownzoom440] #386967
07/28/09 12:23 PM
07/28/09 12:23 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I used to have the dual line external oiling system and because of drain back i would always be priming it, this may have caused the bush to wear.
Ari
Did your erratic timing lose you much power.
Mick
best 60ft 1.36
