Re: WOT and no PCV question
[Re: Jeepmon]
#386532
07/25/09 11:38 PM
07/25/09 11:38 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
I use two PVC valves and two breathers, one of each in both valve covers. My stroke(4.300) is a little longer than yours so you may not need both PVC valves, I used a T off of the PVC port on the carb so there is one hose to each PVC valve The motor idles better now also
[Re: Jeepmon]
#386536
07/26/09 01:33 AM
07/26/09 01:33 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Well pressure in the crankcase can certainly cause RTV to get blown out from under the intake. Or it could simply be that the RTV did not properly adhere the first time it was put on.
[Re: 493_DART]
#386538
07/26/09 10:13 AM
07/26/09 10:13 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
We run 2 Bbs and a SB with just breathers.None have problems.They are street driven and raced.My kid 62 still has the OE motor and gets driven more than most cars here.I run 12.5 domes and it sees 7K all the time.No leaks and no problems.The SB is built also.Rocky
Chrysler Firepower
