W5 valve seal issues ??
#386510
07/25/09 11:16 PM
07/25/09 11:16 PM
Posts: 428 Mountain City, TN
JesseR
Mountain City, TN
Has anybody running W5's had trouble with valve seals before? We've went from teflon to vitons and still have issues. Has anyone tried to plumb drain lines from the back of the heads to the pan? The seals are submerged in oil all the time. I've not restricted the oil to the rockers either and i'm wondering if that would help matters any, thanks, jesse
82' dodge pickup with a 499 low deck
Re: W5 valve seal issues ??
[Re: DavidDean]
#386512
07/25/09 11:46 PM
07/25/09 11:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you haven't cut drain slots in the spring pockets you will need them to help drain the oil. cut a notch about .125 on the push rod side of the spring pocket. Sorry I dont have any pictures.Try doing a W-5 search.
Yeah you have to cut drains in the spring pockets, thats the bad thing on W-5s
[Re: goldmember]
#386517
07/26/09 08:58 AM
07/26/09 08:58 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
You can't blame the guy doing the casting,it's not his design.
OH sure, blame it on the engineer. It was probably the supplier not following the drawing...
[Re: S/ST 3040]
#386518
07/26/09 09:06 AM
07/26/09 09:06 AM
JesseR
Mountain City, TN
Does anyone have pictures of theses modifications, i'm not for certain where to put the drains. Also how big does the fittings need to be? I was thinking a 1/8 pipe and a 4an line should work. Thanks for the help, jesse
