HI-flow vs Std power valves
#386287
07/25/09 08:22 PM
07/25/09 08:22 PM
Posts: 12,211 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have looked everywhere I know to look and I haven't found the limit of the std power valve. What size PVCRs need the Hi-flow? Thanks!
Master, again and still
Re: HI-flow vs Std power valves
[Re: DaveRS23]
#386289
07/25/09 09:02 PM
07/25/09 09:02 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
My last two carbs came with Hi Flow units and I was told by both suppliers to keep using the Hi Flow units when I changed sizes. They were Promax and Quick Fuel carbs. Maybe one of them can help determine why they are used.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: DaveRS23]
#386291
07/25/09 09:21 PM
07/25/09 09:21 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I am really surprised that this info is not readily avaliable. I checked and the Hi-flows are in stock at a lot of suppliers, so there must be some demand for them. I have looked in Emanuel's Holley book, but it shows the old Holley std flow PV that had the little holes. And he did not say at what PVCR size the Hi-flow PVs become necessary. I'll save you all the long story here, but I think I need the Hi-flow PVs. I would like to know at what point they become necessary before I go to the trouble of ordering them and changing them.
[Re: Dunnuck Racing]
#386295
07/25/09 10:48 PM
07/25/09 10:48 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Thank you for the folow-up.
[Re: Cab_Burge]
#386297
07/25/09 11:37 PM
07/25/09 11:37 PM
Posts: 2,567 Appalachia
RedRam
Appalachia
What are the dimensions(measurements) of the standard window versus the hi flow window?maybe we have all been using the hi flows without knowing what they looked like
Interesting, the standard 6.5 that comes in the rebuild kits is .200" wide x .108" - .110" tall best I can measure. What you guys got?
[Re: RedRam]
#386298
07/26/09 09:22 PM
07/26/09 09:22 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I just got my hands on a new-in-the-package Hi-flow PV. At first glance, I don't see that the windows look any bigger. It will be tomorrow evening before I can pull the a PV out of my carb. When I do, I will try to post some side-by-side pics.
[Re: DaveRS23]
#386299
07/26/09 09:54 PM
07/26/09 09:54 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I couldn't wait, so here is a pic of a standard and a hi-flow, side-by-side (hi-flow is on the right). The windows measure the same. And except for the hi-flow having a darker finish, I can't see a difference. The only thing I can figure is maybe the opening on the threaded end, but I'm not going to tear it up to measure it. Hopefully, I can get the hi-flow in this week, and see if I can richen up my A/F.
[Re: DaveRS23]
#386300
07/27/09 12:31 AM
07/27/09 12:31 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
i might be wrong ...but im going with "Snake oil" . Kinda like the fancy "Hi Flow" air filter i just tested at the track. 0 gain over a $3 O'Reilly filter.
[Re: 493_DART]
#386301
07/27/09 06:22 AM
07/27/09 06:22 AM
YO7_A66
Indiana
Quick Fuel's version of the high flow has 4 doors.
[Re: rdrmod6]
#386304
07/27/09 10:11 PM
07/27/09 10:11 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You're right! There is a lot more deflection to the shaft of the Hi-flow. I like the looks of that 4 window PV. I have .092 PVCRs and could not get it to richen up any more with the 80 mains that the cruise likes. It was plenty rich with 88 mains. Holley offers the Hi-flows in several openings from about 3.5 to 9.5, give or take. Now I can get back to tuning. Thanks to everyone for the help on this!
