Re: Combined WEIGHT of 440 and 727 ?
[Re: 69CHARGERMD]
#386279
07/25/09 09:15 PM
07/25/09 09:15 PM
Posts: 34,942 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Yeah ..well, depends on lift They are some heavy mo-fos !! I think my race motor, mega block must itself weigh about 760 lbs ..its a pig be careful !!
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: 69CHARGERMD]
#386283
07/26/09 03:53 PM
07/26/09 03:53 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Got it out on the 1/2 ton setting ,,, no problem,,, except,,cranking that engine leveler is a beeottcchhh.. Not sure i will put it back in that way or put the trans in from underneath........ Will clean up the motor,,,,and re-install with a new CRT trans,,,,
[Re: 69CHARGERMD]
#386284
07/26/09 04:02 PM
07/26/09 04:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Doug, I use a air ratchet for the leveler or my impact(which ever is handy). Glad to see your making head way
[Re: MR_P_BODY]
#386285
07/26/09 04:24 PM
07/26/09 04:24 PM
69CHARGERMD
KENTUCKY
hhmmmm, I must have the cheap leveler,,,Harbor Freight i think,,, It just has a hand "crank",,,,no provisions to attach a impact....but that sounds trick to me,,,sounds like it would make things much better...
I was really wrestling with mine,,,what a pain,,,with the motor way in the air,,,hanging over the car...
I should probably find a better one........
[Re: 69CHARGERMD]
#386286
07/26/09 05:03 PM
07/26/09 05:03 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I've pulled several 440/trans out of cars with those cheaper cherry pickers, never had a problem, i even pulled one out of a 69 NYer with a come-along , thats all i had & it held , its those 2 little bolts that make me nervous that take all that weight, but yet, they still don't break, i'll never forget the time we were pulling a 440 with the trans & i let my step son crank on the hoist, well he's cranking away & i turned my back to do something, next thing you know the f&ckin cars coming off the ground , i'm like wooooo, the trans tail shaft got hooked up on the lip of the firewall (allways does), so those hoist are pretty strong, & yes, the boom was all the way out @ its weakest setting, plus i was useing grade "5" bolts, i don't use those anymore.
