Re: Hood pins on
[Re: bigdad]
#386250
07/25/09 10:23 PM
07/25/09 10:23 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
<----Runs two pins , with steel hood stock latch
Doesn't trust it
I do the same but mines a bolt on AAR fiberglass hood....stock latch and 2 pins and stock hinges.
Post deleted by Defbob
[Re: MR_P_BODY]
#386251
07/26/09 12:45 AM
07/26/09 12:45 AM
Re: Hood pins on
[Re: Quicktree]
#386252
07/26/09 09:34 AM
07/26/09 09:34 AM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
cause dzeus fastners suck, especially with a large scoop. I don't want to be an Eddie and watch the hood blow off at 100mph+. actually been there done that
Get yourself some lanyards- like A-12- so you can keep them with the hood when you lift it off. Lots of pins to keep track of...
Re: Hood pins on
[Re: actionange]
#386253
07/26/09 10:15 AM
07/26/09 10:15 AM
Quicktree
I have them, they came with the pins. just haven't installed them yet.
Re: Hood pins on
#386255
07/26/09 10:24 AM
07/26/09 10:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Why the pin and not zues fasteners
For me I like them as I fear having to pull off a hood in an emergency like a fire with the Dzus
I use to worry about that but I keep a dzus tool in my race pants pocket and another velco'd in the car and the dzus fasteners have WAY less air drag, besides looking better than those trees growing out of the hood...... JMO
Re: Hood pins on
[Re: MR_P_BODY]
#386256
07/26/09 10:27 AM
07/26/09 10:27 AM
Quicktree
by the time you got your old rear end out the car and got the hood off it would be to late
[Re: MR_P_BODY]
#386258
07/26/09 10:32 AM
07/26/09 10:32 AM
[Re: MR_P_BODY]
#386261
07/26/09 11:00 AM
07/26/09 11:00 AM
Re: Hood pins on
[Re: Quicktree]
#386262
07/26/09 11:00 AM
07/26/09 11:00 AM
MR_P_BODY
I don't know,DT seems to run pretty fast with all the air drag. he uses the same pins on his cuda.
Sure dont see them on prostocks.... I know you guys like them because they were put on some of the Mopars so thats fine.... and yes they do work.... again... it each his own(and its your car)
Re: Hood pins on
#386263
07/26/09 11:02 AM
07/26/09 11:02 AM
Posts: 6,295 U.S.
moparniac
U.S.
my new dart has dazues fasteners... not sure if I like them or not yet.... I have an extra hood I might get painted with the 4 pin setup..... hood is the thin kind 6 pack
Mopar Performance
Re: Hood pins on
[Re: MR_P_BODY]
#386264
07/26/09 11:06 AM
07/26/09 11:06 AM
Quicktree
that has nothing to do with it as far as I am concerned. I like them because they are easy and quick to remove. and you don't have to worry about them popping loose and the hood blowing off. thats it. I wont run fast enough to worry about anything else
Re: Hood pins on
[Re: MR_P_BODY]
#386266
07/26/09 11:18 AM
07/26/09 11:18 AM
Posts: 6,295 U.S.
moparniac
U.S.
quik where did you get that hood pin setup.....
Mopar Performance
[Re: Quicktree]
#386267
07/26/09 11:26 AM
07/26/09 11:26 AM
Re: Hood pins on
#386268
07/26/09 11:39 AM
07/26/09 11:39 AM
Quicktree
If the scoop was mounted to the engine like this, you wouldn't worry about the hood blowing off, or bulging down track.
so true Dave, but I didn't build this car. it was like this when I bought it. so it is what it is. If I live long enough to finish my duster it will be like yours was.
Re: Hood pins on
[Re: moparniac]
#386269
07/26/09 11:42 AM
07/26/09 11:42 AM
Quicktree
from summit moroso 3/8" pins
