Any tricks to removing Drag Link OFF front suspension?
#386182
07/25/09 06:56 PM
07/25/09 06:56 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Any tricks to getting the drag link off that runs though the pan ? Normally i just remove the bolts and wiggle/pry it off,,,,
It is on TIGHT,,,,(ie the bar itself,,,the pins and nuts are off)
I had some front end stuff done,,,alignment,,etc,,,everything is OK,,,but this thing does not want to come off....
Need to remove it to pull the motor................
Should the car be jacked up in the air ? or should it be removed with the car on the ground ?
Pickle Fork ?
Pry Bar ?
BFH ?
thanks,,,,,,,,,,,
Re: Any tricks to removing Drag Link OFF front suspension?
[Re: Dart Racer]
#386184
07/25/09 07:49 PM
07/25/09 07:49 PM
69CHARGERMD
KENTUCKY
Problem Solved,,,, "never mind" I used a pickle fork and some "attitude",,,and beat it into submission.... . motor/trans coming out momentarily.........
Post deleted by Defbob
[Re: Dart Racer]
#386185
07/25/09 07:52 PM
07/25/09 07:52 PM
[Re: HPMike]
#386188
07/25/09 09:03 PM
07/25/09 09:03 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
This tool works great, I use it all the time at the shop. I got it off the Snap On truck. Doesn't damage anything. It's OTC 7315A
yep I use something similar to that 'cept mine is a cheapy one from Autozone
[Re: 69CHARGERMD]
#386190
07/25/09 09:52 PM
07/25/09 09:52 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Forty yearsall Ive used is a big hammer and hit it at the right spot.If Im replacing parts pickle fork.Ive done thousands.I can even use the P fork and not damage the boots.Rocky
Chrysler Firepower
[Re: therocks]
#386191
07/25/09 10:02 PM
07/25/09 10:02 PM
only way i can get off the center link is with a air compressed pickle fork.ive tried the hammered pickle fork and it wont come off.
#386192
07/25/09 10:08 PM
07/25/09 10:08 PM
69CHARGERMD
KENTUCKY
Chris, I had enough...lol,,,and went to town on that thing with the BF pickle fork and hammer,,,,, and IT lost....lol never had that much problem getting the link out before.... If the car keeps it up,,,it will never see a new 572...
#386193
07/25/09 10:09 PM
07/25/09 10:09 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Before you re-install everything,give the studs and the tapered seat areas a coat of a good anti seize(I like the Permatex silver stuff).That will help if you have to take it back apart again,assuming you don't use the trick bushings from MR2.
#386194
07/25/09 10:55 PM
07/25/09 10:55 PM
#386195
07/26/09 12:42 AM
07/26/09 12:42 AM
#386196
07/26/09 12:49 AM
07/26/09 12:49 AM
Posts: 705 Michigan
Hemiroid
I will be installing a set of the bushings on Dave's Duster very soon. It's so simple and usefull
I agree, that's a great idea and makes link removal less of a headache on cars that bearing inspect a lot.
#386197
07/26/09 08:08 AM
07/26/09 08:08 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
There's a way to stop those headaches from having to beat off the drag link. Board member Mike Roth MR2PERFORMANCE makes a special bushing .You drill a straight hole thru the drag link and insert his bushings which are tapered on the inside for the tir rod end but straight on the outside. all you need to do from then on is loosen the nut and drop the arms.
That's the way!
[Re: dthemi]
#386198
07/26/09 08:30 AM
07/26/09 08:30 AM
what size hole is it that you drill into the center link?i likee!!! whats the cost for a set of bushings?
#386199
07/26/09 08:44 AM
07/26/09 08:44 AM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
3/4" four bushings are $100 or $25 each for the guys that use heim joints on the outers. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: therocks]
#386201
07/26/09 08:51 AM
07/26/09 08:51 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Agreed all you need is a ball peen hammer. Set your purse down, and hit it HARD (on the side of the centerlink right where the tapered hole is).
I don't even own a pickle fork.
[Re: dizuster]
#386202
07/26/09 10:30 AM
07/26/09 10:30 AM
#386203
07/26/09 10:43 AM
07/26/09 10:43 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
There's got to be a limit on hammer blows before I would start worrying about a safety issue. On some cars the pan has to come off so often it should have zippers
Not to mention that the center link(and other nearby parts that suffer the wrath of the errant blow) will start to look beat and nicked up after doing it this way.
MB
