Radiator interchange #385876
07/25/09 01:48 PM
07/25/09 01:48 PM
Sunny So. Cal.
mopar68 Offline OP
mopar68  Offline OP
Sunny So. Cal.
Is my 68 Charger 26" radiator (AT) interchangeable with other 66-70 b-bodies using a 26" also?
Re: Radiator interchange [Re: mopar68] #385877
07/25/09 04:20 PM
07/25/09 04:20 PM
Andrewh Offline
Andrewh  Offline
pretty much any 26 should bolt in.
But you have to know how many core it is, 2 vs 3, vs 4,
Which side you need the lower hose on.
The shroud might not work for you due to the offset.
Re: Radiator interchange [Re: Andrewh] #385878
07/25/09 05:23 PM
07/25/09 05:23 PM
Sunny So. Cal.
mopar68 Offline OP
mopar68  Offline OP
Sunny So. Cal.
Cool, so it should be able to at least bolt on. Although not really sure what you mean about offset?
Re: Radiator interchange [Re: mopar68] #385879
07/25/09 07:20 PM
07/25/09 07:20 PM
Andrewh Offline
Andrewh  Offline
sb vs bb, some years vs others, 65 and earlier especially you can see it.
The engine is off set a little, and in 65 it was closer on one side than the other.
So depending on what the car had in it, the fan will hit the shroud on the rad if it is a different offset.
Just saying you may have to fabricate something for a shroud.
Re: Radiator interchange [Re: Andrewh] #385880
07/26/09 02:14 AM
07/26/09 02:14 AM
Sunny So. Cal.
mopar68 Offline OP
mopar68  Offline OP
Sunny So. Cal.
Got it! thanks!
